I have a Power Gear slide mechanism. For some reason the slide has sagged and rubs on the carpet when being put out or in. The solution, it seems to me, is to adjust the slide up or perhaps down.
The adjustment is on the skirt of the slide. There is a bolt that when loosened allows the bracket holding the slide mechanism to the skirt to move up or down. There are directions on the Power Gear web site.
I can see the adjustment when the slide is out and that is when it should be adjusted. Maybe you have insulation and a cover that covers the floor of the slide when it is out.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
