โJan-20-2015 06:07 AM
โJan-21-2015 07:09 AM
brulaz wrote:APT wrote:
No brake controller knows when the trailer brakes are locked up.
Sort of blew me away. And haven't heard of any trailer actually using it. Probably very pricey too.
โJan-21-2015 06:47 AM
โJan-21-2015 06:32 AM
โJan-21-2015 04:38 AM
sourdough2224 wrote:
My new 2014 Ram 2500 w/IBC will almost lock them up but not quite.
โJan-21-2015 04:12 AM
โJan-20-2015 05:00 PM
โJan-20-2015 02:09 PM
โJan-20-2015 02:01 PM
exscream wrote:
I have a Silverado with IBC. The instructions actually tell you to adjust the gain until the trailer wheels lock and then back off the gain just enough to avoid wheels locking.
โJan-20-2015 01:40 PM
โJan-20-2015 12:19 PM
Big Love wrote:Drew_K wrote:
I had a Prodigy brake controller in a prior truck and then integrated brake controllers in a prior F150 and now my F250. I could adjust the Prodigy high enough to lock up the brakes on any trailer. With the IBC on the F150 and F250, the max gain was either barely enough to lock the trailer tires or I couldn't lock them.
I suspect Ford intentionally programmed their IBC with less gain so people wouldn't use too much. You have to decrease the gain in slippery conditions and folks may forget to do that; next thing you know the trailer tires lock up in the rain and the trailer swings around.
Frankly, I think the Prodigy works a lot better than the Ford IBC. You can't adjust the gain high enough on the Ford. The Prodigy was much quicker to apply trailer brakes; the Ford has too much of a delay. The Prodigy also applied a more appropriate amount of trailer brakes. Granted the Ford IBC has sway control but I load my trailers/RV appropriate so sway has never been an issue for me.
Exactly what I have noticed in my 2014 F-250! I cannot get my brakes to lock up at 10 volts, and then back the voltage down to get a proper adjustment like I could with my prior TV. I think I will set it at 8 or 9 volts and hope for the best. The TT service manager told me that many IBCs do not allow full voltage to brakes, but only a proportional amount depending on speed and other factors.
By the way, I know my TT brakes work since the TT wheel locks up when I pull the safety switch on the tongue.
โJan-20-2015 11:37 AM
โJan-20-2015 11:08 AM
โJan-20-2015 06:29 AM
โJan-20-2015 06:27 AM
