According to this article, the max GVWR is 6250 which you didn't list for your particular truck.
https://en.wikipedia.org/wiki/Ford_F-Series_ninth_generation I'm surprised that it only weights 4300, but if that's right for your truck, you'd be under of the very max GVWR.
The key is where the weight is though. You would need to go to a scale to see how much weight is actually on the rear.
