Oct-28-2020 05:18 PM
Oct-29-2020 04:01 PM
Oct-29-2020 03:41 PM
4x4ord wrote:"3.42's should yield close to 10% better fuel economy while running empty at virtually any highway speed" vs. a 4.10. Interesting. Not what I've experienced.
According to the BSFC map for the 6.7 Cummins that Shiner posted on another thread the 3.42 pulling in 5th vs 4.10 in sixth yield very similar MPG while towing. 3.42's should yield close to 10% better fuel economy while running empty at virtually any highway speed. Again, according to the same BSFC map, towing with 3.73 gears at 65 mph should offer a slight advantage in MPG over either 3.42's or 4.10's. Empty the 3.73 will fall half way between 3.42's and 4.10's . . .
Oct-29-2020 02:36 PM
MikeRP wrote:
Hey
I know we have a big thread on fuel mileage going. I’m considering a 2020 Ram 3500 Crew Cab with the HO Cummins/Aisin and it has the 4.10 gears and it’s a dually. On a test drive it appeared to be doing around 2000 rpm at 70 mph.
Oct-29-2020 02:29 PM
Oct-29-2020 01:23 PM
Oct-29-2020 11:20 AM
Oct-29-2020 08:29 AM
otrfun wrote:
Our '16 Ram Cummins' overall gearing in 5th gear with a 3.42 rear end is more or less equivalent to a 4.10 in 6th gear. After numerous cross-country trips with various 10k-12k 5th wheels and TT's we've noticed no difference in fuel economy driving at 65 mph in 5th or 6th gear. We always tow in 5th to reduce downshifting (and wear and tear to the tranny) and to keep the Cummins more responsive (at 65 in 5th it's at 1,700 - 1,800 rpm, operating at peak torque). Another added plus, the exhaust brake is also much more responsive.
IMO, the only situation where the 3.42 or 3.73 gears *may* have an mpg advantage is driving at 80 mph EMPTY in 6th. I could see a possible 1 mpg increase in fuel economy vs. a 4.10 in 6th at 80 mph.
Me, I can't see the logic in purchasing a $70k-$80k truck that's main purpose in life is towing/hauling heavy, then reduce its tow capacity via higher driveline stress with a 3.42 rear end . . . over a possible or, at most, a negligible increase in fuel economy. IMO, it's a no-brainer to go 4.10---unless your main goal is a slight increase in fuel economy driving at 80 mph EMPTY.
YMMV.
Oct-29-2020 08:20 AM
Oct-29-2020 08:11 AM
Oct-29-2020 07:45 AM
Oct-29-2020 06:06 AM
jdc1 wrote:
Well, let's start with Ohio's 55mph towing speed limit......That alone will improve your mileage by 15% or more.
Oct-29-2020 05:23 AM
jdc1 wrote:MikeRP wrote:
Jdc1: Ohio hasn’t been 55 for a long time. I think it is 65 mph now on Freeways.
ShinerBock: you are right I will consider stepping back to the standard Cummins and the 3.73. Plenty enough to tow 14,500 lbs.
I just looked it up.....towing speed limit in Ohio is 55mph.
Oct-28-2020 07:17 PM
Oct-28-2020 07:13 PM
Oct-28-2020 06:54 PM
