Hippilongstockings wrote:
Also--I've been doing a lot of research in Armada forums---and everyone said they didn't have a problem towing something of that size. It's got a V8 and a tow package, although I do understand the shorter wheel base might present a problem.
Now--I think it might be pushing it a bit, and I would personally like to be under 6K dry weight. I feel like I could comfortable tow it, and wouldn't have a problem.
If what I'm looking for is too nuts---please give me some suggestions.
Thanks!
2005 NISSAN TOWING GUIDEFrom the 2005 Nissan Towing Guide..
2005 ARMADA TOWING DATA
Engine Type 5.6L V8,Transmission A/T
Model(s)
Maximum Trailer Weight
without optional tow package
4x2, 6,500
4x4, 6,500
with optional tow package
4x2, 9,100
4x4, 9,000
Maximum Trailer Tongue Load (lbs.)
4x2, 650
4x4, 650
4x2, 910
4x4, 900
Gross Combined Weight Rating (lbs.)
4x2, 12,800
4x4, 13,000
4x2, 14,600
4x4, 14,822
Additional RECOMMENDED
Equipment
Sway-Control Device
Weight-Distributing Hitch Ball Mount (Class IV)
Armada Curb (empty) weight 4x2 about 5,013 and 4x4 about 5,168
The problem here is in order to tow a max of 9100 lbs you would have a min of 10% of the tongue weight which is 910 lbs. 10% is the BOTTOM most spec for tongue weight, ideally 12%-15% is where you should be..
15% of 9100 lbs is 1,365 which puts you well over the allowed hitch weight!
To get 15% hitch weight you would HAVE to have an absolute MAX trailer weight of 6000 lbs! which would get you right at 900 lb mark.
BUT the 900-910 hitch rating is only good IF your vehicle is equipped with the OPTIONAL TOW PACKAGE.
If not equipped with tow package then you are only allowed 650 lbs MAX hitch weight!
That would put you at a MAX of 4,000 lbs for 15% tongue weight!
You simply are asking way to much of your vehicle if you exceed 4K (without tow package) or 6K (WITH TOW PACKAGE).
Pretty darn hard to find a 30ft bunk house under 4K EMPTY..
My suggestion is to find out if your vehicle has the optional tow package, then go from there.
Realistically you need to be looking for a trailer which has a GVWR of 7K OR LESS and ignore the dry or empty ratings. If you do not have the tow package then you are going to be limited to extremely small lightweight trailers (under 20ft) and would have GVWR under 5K...
On edit.. forgot to mention that you need to take in account the weight of your Weight Distribution hitch.. This will easily add 150 lbs of hardware to your hitch weight...
You also need to find out the cargo rating of your Armada since your passengers and any gear placed in the vehicle will take away cargo capacity. This may affect how much hitch capacity you will have leftover since the max hitch weight is figured into the cargo rating of the vehicle.
