problem finding the cause of a roof leak
Possilian
Getting rather frustrating but I got a leak between the bathroom door and the roof vent in the bathroom. Rheir is the sky light in the middle of it as well. 2013 arctic fox 990 tjat I just re caulked. Thought that I had it before this last storm it leaked again. I did peel and clean the old stuff off and took my time over two days getting the new stuff down. Just thinking to myself, WHAT COULD I HAVE MISSED! Any advice would be appreciated. And it only leaked in very big storms twice now.
21 REPLIES 21
RockyRoadCamper
A rv repairman told me to remove all suspected caulking-CLEAN WITH MINERAL SPIRITS-then apply Dicor to rubber type roof and apply a good silicone sealant to fiberglass roof parts.
Turns out my "leaks" I am now sure are condensation problems.
kerry4951
I went around my shower skylight with Eternabond tape. I brought the tape up a few inches on each side of the dome.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
Possilian
CPaul, you were on the spot. Crack around the bottom edge near a corner. Verified it was there by using my knife to find the separation. Sealed everything to the top edges and after last nights rain storm it was dry! Hopefully no problems till i get back home and I am going to redo everything and fix that skylight.
PaulJ2
Had a leaking skylight over the shower that I tried sealing everything in sight. Flange around it, every screw head I could find and still leaked.
Finally located a tiny hairline crack in the corner of the skylight itself, very difficult to see. A bit of sealer tape stopped it. Will replace the entire skylight later.
JacintoKid
Sue Bee wrote:
Just because you have a leak coming out one place doesn't mean that the water isn't coming in somewhere else and seeking it's level.
Your AC unit, that skylight, any intrusion in the roof is suspect. But we've had a never ending issue with our ^%$@!!! Heki Skylight in the Bigfoot leaking because the thing is so stupidly designed and installed. ***I*** could have designed and installed that thing better in my sleep. And any time we take a trip with the Bigfoot, it is time to check the seal around it, because it seems that the Plasticote doesn't flex well.
Is the Eternabond tape more flexible than the Plasticote goo? I might just bite the bullet and try that.
Sue Bee mentioned the AC. Have you ever gone back and tightened the 4 bolts inside the AC cover? they often wiggle loose and need to be re-tightened periodically. Your water may be getting past your AC/Roof gasket and running toward the bathroom. It's a good thing to check anyway.
2014 Toyota tacoma 4WD
2014 FourWheel Camper Fleet model
OME full suspension swap
Sue_Bee
Led_67
bobndot wrote:
scroll down and look thru 'members projects' in TC university ... to see if there is a home-made version of the seal-tech testing system.
An rv shop will charge about $150-200 or so to do the seal-tech test .
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25966285.cfm
seal-tech explained with pics
When I had my roof leak, I covered the vent with a Rubbermaid container turned upside down , then used a sprinkler to see if it leaked when it was covered. If the leak stopped then you found the culprit.
I used Eternabond tape once I was 100% sure where the leak was coming from. Its difficult to remove that e-tape once its in place .
Good luck, I hope you find it , Bob
And here is the Low Pressure Test
Hope you have or can borrow a leaf blower.
Good Luck
Possilian
Joe, I did the mounts when I was up there. Actually did the entire roof wherever there was something going thru it. Going back up this weekend woth a hose and some weighted plastic bags to test it. Using the bags to make a isolation wall as I go. Maybe I will find it that way.
Joe417
I had a similar issue. My leak was a small crack in the sealer on the bath vent. It would take a while to leak unless it came a down pour.(Or I flooded it with a water hose)
I removed the skylight completely. That let me see the path the water was taking. The water carries dirt and in my case green algea to mark the path. Obviously, it had been leaking for some time.
It came in and ran under the Dicor along the back edge of the vent fan. The water then ran under the butyl putty at the left rear corner of the skylight, dripped down and ran across the inside face frame of the skylight and dripped out on the right side.
It was easy to reseal. But resealing the skylight would not have fixed the problem permanently with out resealing the vent.
From your description of where the water is dripping, there are also the roof rack mounts approximately over the door, with one almost touching the skylight. (I'm assuming the same floor plan as my 05 model)
I have a mental issue with just stopping the problem, I usually make an experiment out of it. But that way I know it's done right and how it's put together.
Good luck,
Joe and Evelyn
Mello_Mike
x3 on the Eternabond Tape.
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
Possilian
Hey bob, you are from up near my home. Avoca, exit 1 390. Who do you use for a dealer. I liked wilkins till they got big.
I do move so much more since getting in my tc. Figured that is why I had to service it so quickly. I have been out since mid december. Funny thing about this leak is it only appears when I get a really windy storm! Sat in rains a few times since my repair and no leak even in fairly heavy rain. Weird. And it drips above the bathroom door. Pantry is dry as is most of the bathrrom ceiling next to the walls. dripping like crazy from the upper door fasad right now. Central florida is getting rocked by lots of storms tonight.
kerry4951
Possilian wrote:
Did you guys use the tape or the eternabond caulk?
Tape
bobndot
quote wrote:
My wife is making me feel the butt end of a few jokes at the moment. Like reminding me of nearly sinking the boat when I forgot to put the plug in. Also when I forgot to close the vent over the bed one day and the bed was soaked!
If you should ever have a leak on her side again...hand her an umbrella 🙂
bobndot
