โJan-31-2014 11:25 PM
โFeb-03-2014 04:19 PM
gheicher wrote:LewBob wrote:
I have been quite satisfied with my Battery Minder. I take the two 12-volt batteries off the trailer and into the garage (for convenience), hook them to the Minder and check water level, just in case, about once a month.
When charging multiple batteries, it is my understanding that it is best to charge the battery individually and a bit risky to hook batteries directly in parallel. A diode should be used for isolation in case the batteries are at different charging levels.
โFeb-03-2014 03:54 PM
โFeb-03-2014 12:22 PM
Chuck_thehammer wrote:
I use a "battery tender"... brand, battery maintainer
same with motorcycle and generator batteries ....
โFeb-03-2014 11:31 AM
โFeb-03-2014 10:20 AM
โFeb-03-2014 04:42 AM
smkettner wrote:
+1 for solar. Especially in TX.
โFeb-01-2014 12:54 PM
โFeb-01-2014 11:26 AM
โFeb-01-2014 11:19 AM
Lew
โFeb-01-2014 06:57 AM
โFeb-01-2014 06:47 AM
hotqld wrote:
a solar panel on the roof so it charges your battery all the time.?
โFeb-01-2014 06:40 AM
Lowsuv wrote:I thought leaving the charger on was a bad thing, too. Turns out that leaving a small amperage charger on your batteries is about the best care you can give them. I got this from Enersys battery data sheets and advice from this Forum.Tvov wrote:
I usually disconnect the battery between trips. About 3-4 days before we go on a trip I reconnect the battery, plug in the TT at our house, and the battery charges up (and we cool down the refrig).
Seems to work fine for us.
I agree .
Been doing this for over a decade .
A battery will freeze and crack during winter freezes if it is uncharged .
I disconnect my TT batteries fully charged after a trip .
We dry camp without hookups about 70 %
We connect the batteries and plug the TT into 120v at home while packing.
Charge them with the stock duramax alternator for the minimum couple of hours to our destination .
I think this method is less stress than leaving the batts on a trickle charger .
โFeb-01-2014 06:11 AM
โFeb-01-2014 05:45 AM
I agree .
We connect the batteries and plug the TT into 120v , (about 24 hours)at home while packing.
We dry camp without hookups about 70 % so good batts are important .
no genny . no solar . 9 day to 2 day boondocks camping .
