โJan-25-2014 05:15 PM
โFeb-03-2014 03:50 PM
aftermath wrote:
You might want to take a look at the Anderson hitch. It is relatively new on the market but it does have a pretty good following.
First, weight distribution. You might not need it. As long as your loaded set up doesn't drop the rear end of your truck to the point where the front wheels are too light, you should be good. Losing 160 pounds doesn't sound like a dangerous situation to me.
Sway control? All trailers are different. Some just tow easier and more stable than others. I tow and Airstream and it really rides nice back there. Do I need sway control? Probably not. I choose to have it since I do need the weight distributing hitch. I am glad that I have it because you just never know what kind of situation you might find yourself in.
I was coming down a very long and winding hill in California a few years ago. It wasn't all the steep but at the bottom there was an Airstream on its side in the median with the TV on the right side of the road. He was towing just on the ball and it looks like he lost it to swaying. There were marks on the road that looked like it was going side to side before he lost it. Speed, wind, hills, passing cars/trucks, bad road conditions, rain, snow are all issues that can create sway. Having a good anti sway hitch does not absolve you of all threat but it does help keep things under control better than the alternative.
โFeb-03-2014 03:37 PM
โFeb-03-2014 06:20 AM
โFeb-02-2014 09:21 PM
โFeb-02-2014 06:53 AM
โFeb-02-2014 06:03 AM
โFeb-01-2014 09:22 PM
โJan-29-2014 02:32 PM
โJan-28-2014 04:03 PM
myredracer wrote:
I thought there was one that you can't back up with and thought it was the Centerline. Maybe it's another one or it was that you had to be in a straight line with the Centerline?
Snip...
โJan-28-2014 01:13 PM
โJan-27-2014 05:47 PM
handye9 wrote:I do not think the Andersen WDH would suit him best.
I too, would recommend you get one. The one I think would suit you the best, is this one.
It's clean (no need to carry grease or lubricant of any kind), quiet (no moaning and groaning of WD bars), lite weight (60 lbs total weight), and has been reported to work very well with liter tongue weights.
โJan-27-2014 05:21 PM
โJan-27-2014 04:46 PM
โJan-27-2014 04:26 PM
BarneyS wrote:myredracer wrote:
Snip...
AFAIK, the only WDH you can't back up with is the Husky Centerline.
:h Where did you hear that? I have never heard of a WD hitch that you could not back up with. Even the very common friction sway bar equipped WD hitch can back up as long as you do not exceed the limits of the sway bar.
Barney
