โJul-16-2017 05:49 PM
โJul-18-2017 07:19 PM
JFNM wrote:
I agree, it sounds like you have a battery bank made of two batteries connected in parallel. Assuming that is correct...
Going back to your original question, the 100W panel will charge the battery bank. However; keep in mind that 100W is slightly less than 7.5 amps at 13.5 volts (minimum charging voltage) and that assumes the panel is working at 100% (they rarely do that). So, it is not a lot of charging but certainly better than nothing.
โJul-18-2017 06:39 AM
โJul-17-2017 07:06 PM
I do not believe any controller can properly charge two independent batteries from one pos/neg cable. The controller needs to sense battery voltage to know "how" to charge the battery - if there are two batteries connected (not a bank), the controller will not be getting accurate information. Are you sure you do not have two 12V batteries wired together in parallel to create one 12V battery bank? (a charge controller CAN charge a bank of batteries).
โJul-17-2017 07:06 AM
โJul-17-2017 05:58 AM
โJul-17-2017 05:14 AM
corvettekent wrote:
Disconnect the panels and check the voltage at the panels in the sun. If you get 0 volts then replace the panels.
โJul-16-2017 08:00 PM
โJul-16-2017 07:11 PM
โJul-16-2017 06:41 PM
