โNov-05-2021 07:28 PM
โNov-29-2021 06:20 AM
TxGearhead wrote:
Foldable shop crane (engine hoist), 2,000# capacity from Harbor Freight. $229. Maybe $20 worth of light duty chain and 1/4" shackles will get that tailgate off by yourself.
โNov-28-2021 07:40 AM
โNov-16-2021 06:17 AM
mkirsch wrote:Fishbreath wrote:Geo*Boy wrote:Fishbreath wrote:
Thanks for the replies!
With regards to weight on the tailgate with the camper loaded, the Northstar popup has an 8 foot footprint and does not hang over past the floor of the truck bed.
I had no desire for the ProGrade tailgate when I ordered the truck, but, it came standard with the trim package that I ordered. I have also learned on-line, that the ProGrade tailgate will smash into a trailer ball if one is installed in the receiver. There are a lot of unhappy people on the net that have pushed the button to lower the gate and have had it hit the hitch ball, leaving a dent in the tailgate. Two companies have already designed work-arounds to prevent this. One is an electronic switch that senses you have a hitch ball installed and stops the tailgate from lowering. The other is a specially-bent hitch/ball combo that drops the ball lower and also tucks it in a little. GM failed to field test this new tailgate while towing. Just a little frustrating.
I'll update this situation once I get the tie downs installed and do a trial fit.
Thanks!
B&W makes a nice tow ball setup that flips inward so the gate doesnโt hit the ball.
I have seen the B@W hitch. Unfortunately, you still run the risk of damaging the tailgate if you forget that the hitch ball is installed. It would be easy to oversee because the darn thing is mechanized and can be opened/dropped from inside of the cab.
TOO MANY GOODIES!
Seems I remember seeing a youtube ad recently about some device that you can add to your tailgate that will keep it from dropping if there is a hitch in the receiver.
โNov-16-2021 04:45 AM
Thanks!
TOO MANY GOODIES!
โNov-16-2021 04:42 AM
Grit dog wrote:mkirsch wrote:
I have often warned people that is the main drawback with leaving the tailgate on. You could run one of those goofy mustache things across your rear bumper to catch any rocks thrown up by the wheels until they fall off and you give up on the idea.
Yes, the trucks are taller because everyone just goes and puts at least a 2" lift kit on them as soon as they get them home, right? The jacked up truck look is "in" right now.
Also if you want a truck that doesn't have the bells and whistles you can get one. Just find a dealer that does fleet sales. They usually have a line of plain-jane trucks on the lot. Who cares if it's white? That's the most popular color right now. Besides you can always get it vinyl wrapped in any color you want.
You forget to take your Metamucil this morning? This whole post is bitter and laughable at the same time.
And PS, the OP "purchased" as in past tense, already bought the new truck, so guessing he doesn't just want to go down to the fleet dealer and get ANOTHER NEW truck.
And getting it wrapped? Sure it's an option. An expensive temporary option. Especially considering we're talking about a minor or even just potential issue with a tailgate that literally can be removed in 1 minute, and if the swiss army tailgate is ACTUALLY prohibitive for the owner, a new/used, traditional tailgate can be purchased way cheaper than trading a new truck for another new truck and then getting it wrapped.
What you suggested is akin to needing to go to the grocery store for a few things, but rather than drive to the store and pick up your items, you book a flight to another city, fly there, uber to a store, get your stuff, check a bag and fly home....
โNov-15-2021 06:50 AM
โNov-11-2021 05:18 PM
Deb and Ed M wrote:
I have a Northstar PU TC 8' floor, that I haul on a 6-1/2' bed truck with the tailgate lowered. Before loading, I just cover the back of the tailgate with Transit Shield (also called Tansport Wrap) to protect it. I'm still using the stuff I bought in 2006 to go to Alaska (and used it to protect our Class C.)
โNov-10-2021 07:58 AM
โNov-09-2021 04:20 PM
Thanks!
โNov-09-2021 01:22 PM
Thanks!
โNov-09-2021 09:42 AM
โNov-09-2021 08:08 AM
โNov-08-2021 11:44 AM
โNov-08-2021 10:17 AM
Fishbreath wrote:
KD4UPL:
Thanks for the reply. I thought more people would chime in regarding the tailgate issue. I had not thought of the "rock chips" as a potential problem. I guess I will have to get that clear film that is popular on the front of cars plastered onto the tailgate to protect it.
It's funny you mentioned the heights of the newer trucks. This 2022 has to be 2-3 inches taller than my 2019 3500. Makes no sense.
Bill
