Fishbreath wrote:
KD4UPL:
Thanks for the reply. I thought more people would chime in regarding the tailgate issue. I had not thought of the "rock chips" as a potential problem. I guess I will have to get that clear film that is popular on the front of cars plastered onto the tailgate to protect it.
It's funny you mentioned the heights of the newer trucks. This 2022 has to be 2-3 inches taller than my 2019 3500. Makes no sense.
Bill
Bill, there's some mis-info being thrown, as absolutes, around here I'd like to clarify.
First, rock chips can or will be a problem, but the rocks are easily defeated by rear mud flaps. Which will also keep the rear fenders from getting chipped up just the same. Put lotsa miles between here and Alaska and around Alaska, 100s of miles of dirt and gravel roads, maybe thousands, no rock chips on the tailgate with it in the down position under our truck camper.
Tailgate damage from camper weight? I cannot speak to the new multifunction GM tailgates although their level of complexity leads me to think they will not handle heavy use like a solid tailgate.
But, speaking for 1 piece tailgates, it is highly likely you could leave it on the truck even with the camper sitting on it. With the following considerations.
- Tailgate surface is at or below the plane of the truck bed. If it's raised at all from the truck bed surface then the tailgate will be supporting weight that should be taken up by the truck bed = not good.
- Camper is not designed to be fully supported by the truck bed (IE 8' camper in 8' bed and not designed to support itself with any overhang out the back of the bed.) Highly unlikely in most scenarios, as most campers DO overhang some amount and are designed as such. If it is not self supporting, then it's remotely possible, but not probable, that it could exert too much weight on the tailgate.
Our old short bed Dodge hauled a 4000lb, almost 9' long TC for about 20k miles? Had a couple small dents and wear marks where the camper sat on it. Dents were matching the bottom of the truck bed, where the camper itself dented the truck bed as well.
Guy that bought the truck and camper together last year has basically been cross country a couple times with it with the camper since. He has had no issues in this regard either.
- In 30+ years of using and abusing (landscaping and construction) 100s or 1000s of tailgates, I have yet to see one just "break." And I'm talking tailgates that are so bowed, bent and banged up that the sheetmetal may be cracking and they look like they are smiling!
If you are able to analyze how your camper "fits" with the tailgate in place and not just going about it blindly, you can absolutely leave the tailgate on and not damage it.
2016 Ram 2500, MotorOps.ca EFIlive tuned, 5โ turbo back, 6" lift on 37s
