No heat / Furnace not working
kode9
Hi.
I bought in August a Grand Design 297QB brand new and while I did test everything there - on the RV lot - and then, nowadays when temperatures start to drop, the heater is not working.
It did work for a couple of hours back in September, but now. Nothing. Nada. NONE.
And all I did then was to just to increase the temperature of the thermostat from 75 to 82( or something like that ) and heater would work.
Now if I do the same, the only thing that comes out is cold air.
The thermostat is a Coleman-Mack.
Must mention that I am complete noobie when it comes to RV/Traver trailers and so on.
Thank you.
10 REPLIES 10
kellem
Each time I've had a furnace failure, had to replace the sail switch.
canoe_on_top
It's new. Take it back to the dealer. I had a furnace in a class C that worked fine until the temp got below freeziing. Then fan would run but only cold air. Stove worked. Turns out it was moisture in the regulator. The regulator would freeze. It would allow enough propane for the stove to work but, not the furnace.Had to replace the regulator and purge the tank to get the moisture out.
morphrider
I would also check to make sure the fresh air intake from the outside is clear of any debris. I had a pop up camper years ago that I tried everything to get heat on. Finally on the day I sold it, literally, I found a 2 wasp nest in there. It was very small but heat kicked on right after, dohโ€ฆ
zigzagrv
Like most noobs who come on here lately. we will probably never know the outcome. :R
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
CavemanCharlie
WayneAt63044 wrote:
The furnace heats using propane; are the tank valves open?
And are they full ??? Have you used the stove or any other propane item ? Have you tried the stove to see if it will light ??
ktmrfs
it's not just "are the tanks open?" it's also is the excess flow valve closed? Easiest way to have propane problems with tanks made in the last 15 years or so is to open the propane valve to fast. SLOWLY is the word of the day. To check if there is enough flow, light the stove burners. if you get a good flame on high your ok. If all you get is a weak flame, turn off the propane tank, disconnect the hose, reconnect the hose and make sure it is ALL the way tightened. then SLOWLY open the valve. Check the stove.
Oh, and make sure you have propane in the tanks!
Next, on the thermostat make sure it is set to heat, not cool or fan.
2011 Keystone Outback 295RE
WayneAt63044
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
enblethen
Access you furnace, varies between makes and models, locate the two blue wires. Connect them together. Furnace should start and produce heat. Separate the wires, furnace should go into cool down mode.
If it operates in that manner, thermostat is bad.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
zigzagrv
Are you hooked up to shore power? If not, your battery may be low. For the furnace to go on the fan must blow hard enough to operate the sail switch, which tells the furnace to ignite and that you have enough air to circulate the heat. Battery should be at least 12.3 volts.
Ron
F53 Class A
2013 Ford Edge toad
wanderingbob
Did Ya try the " auto position ?
