Noisy Suburban Furnace fan
LVJJJ
been researching all the Suburban furnace repair sites and here. None of them mention my problem on a 2004, NT16SE. The fan motor is very noisy and even rattles loudly once in a while (wakes us up at nite), and the whole furnace even vibrates a little.
Took the insides out of the metal box and found that the motor shaft moves back and forth a little and makes a metallic noise that probably creates the rattle. The fan rotates evenly as does the combustion air wheel. I thought an electric motor shaft would have a little play in it?
It seems obvious to me that the motor is worn out but just want to be sure before ordering a new one at $80. I tend to diagnose problems before taking things apart.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
11 REPLIES 11
enblethen
Thanks for the update!
Now that you have it fixed, the weather will be warming up!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
LVJJJ
FIXED! Ordered a new fan from American RV ($82), put it in, works great, no vibration or loud rattleing. Was pretty easy to take out and install.
2008 HHR
enblethen
Just tell her she is my girl friend! She has money! Don't think her husband will let her spend much on me.
Bud
USAF Retired
Pace Arrow
LVJJJ
enblethen wrote:
Call Louise at 360 659-7833
what if my wife finds out?
2008 HHR
old_guy
$80 is not bad, have seen some go for over $100
CavemanCharlie
You say the shaft moves back and forth. Does it move in and out, or, up and down. If it's moves in and out the problem could be too much end play. If it has too much of that maybe the fan is dragging on the housing and you could find a way to give it more room to move and then save yourself a few bucks for a few years .
If it is too much end play I have taken fan motors apart before and found a way to add a new thrust washer; made out of something; and eliminated the end play.
If you are thinking of throwing it away anyway you have nothing to lose by dissembling it.
enblethen
Bud
USAF Retired
Pace Arrow
LVJJJ
the furnace is an NT16SE, the OEM motor part number is 230634, the replacement number on most parts sites comes up as 520950. the price ranges from $70 with $15 shipping and as much as $94 plus shipping. Couldn't find anything on Grainger.
2008 HHR
Toddupton
$80 sounds way to high for that motor. Look it up on Grainger and that will give you an idea.
downtheroad
Bearing failure...maybe.
I don't think you can lube anything...sealed system.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
enblethen
Bad fan motor!
$80 seems a little high. What is model number on the motor? Or what is exact model number of the furnace?
Bud
USAF Retired
Pace Arrow
