Northwood MFG Vinyl Trim Insert issues
anutami
has anyone dealt with their plastic trim on either Arctic Fox or Wolf Creek cracking and falling apart so fast? The plastic trim on my wolf creek is literally falling on the ground and cracking everywhere. My camper is only 2 years old and that seems pre mature to have to replace all the trim.
can anyone recommend a trim that will not fall apart so quickly and not turn yellow?
looking on amazon I found thistrim clicky but it looks like the same stuff Northwood uses.
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
20 REPLIES 20
trail-explorer
It's aesthetic, to cover up the screw holes that hold the trim on.
Bob
joeshmoe
I think it's mostly just to keep dirt, debris and the majority of pelting rain water out of the channel, and some aesthetic. Otherwise, it'd look like the rain gutters/spouts. It's certainly not sealed as there are drain holes on the underside of the cabover.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
hedge
Mine is also damaged but I thought it was from hail. Does it serve a purpose to help with sealing or is it just aesthetic?
I wasn't that worried about it but maybe I should be, kept forgetting to measure for the correct size.
2017 F350 Platinum DRW
2013 Adventurer 89RB
deltabravo
Link works now. THere was a space at the beginning which I removed.
The trim insert I used does not stretch, so there's no way to jam extra in to the slot.
It doesn't fail due to shrinking, it just disintegrates to to sun exposure and becomes brittle
covered_wagon
Got mine at Apache Campers in S.E. Portland. They must have the good stuff because it's held up well. Redid entire camper, made it look brand new again except for some basement squish, p.o.s.,I still love it.
JoeChiOhki
towpro wrote:
mike/kellie wrote:
I replaced sections on my 5th wheel that had shrunken out of the track on the inside radius. Don't stretch it when you replace. Very easy but surprised it's happened so soon.
in fact I try to push extra in as I install it giving it room to shrink.
If you anchor the ends of it with a screw cap, it doesn't shrink up.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
joeshmoe
Linky no good
Rancho 9000's
deltabravo
Like yours. mine started falling apart in thin strips.
I took some photos of the project: Trim replacement Scroll down a ways to see them.
deltabravo
The front trim fell apart a few years ago and I replaced it.
Last year, all the trim on the sidewalls at the roof line, and all of it on the back wall started disintegrating. I finally got it replaced a few weeks ago.
I'm sure it will happen again in a few years.
The same thing happened on my Desert Fox 21SW. The stuff I replaced it with was more like a vinyl material, not the rigid hard stuff I bought for this project. I can't seem to find the vinyl like material any longer.
trail-explorer
Sun / UV kills it. It's not a problem specific to Northwood units. It's more a "how soon the trim falls apart depends upon the region the camper is located in / sun exposure."
Bob
jimh406
This is the replacement I bought which is very thick. http://www.amazon.com/RV-Designer-E461-White-Insert/dp/B003YJI06K
towpro
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
Bubtoofat
Classic case of a batch with little or no UV stabilizer. It happens. Part of my job is doing xenon arc accelerated weathering on automotive plastics and even some lots from the top manufacturers fail now and then. Chances are slim it will happen again when you replace it.
Mike
2005 Chevy 2500HD Crew 4X4 6.0
2011 Northstar Adventurer
Hellwig Bigwig, Ride-Rites, Fastguns, KYB Monomax.
"No matter where I am, I can't help feeling I'm just a day away from where I want to be."
Jackson Browne
joeshmoe
I figured that's what did it.
Rancho 9000's
