Noticed warm water comes out of cold faucets. Why?
Crambo
Noticed it last night in the shower and today the wife mentioned it after using the bathroom sink and kitchen sink. Hot water faucet delivers good hot water and I haven't messed with anything since we have been camping regularly. Any thoughts? I was wondering if maybe the water is just warm because it's in the mid 90's with heat index of 100 to 105 but it feels unusually warm.
16 REPLIES 16
Searching_Ut
I'm with the folks suspecting solar heating of the hose and other plumbing. Over the years I've found it common for the water in the hose and plumbing to get pretty warm through the course of the day, especially if the hose is in the sun.
When camping on the nice warm sands of Saudi Arabia thanks to Uncle Sam, we were using water bladders sitting out in the sun and filled by tanker trucks to provide water for showers. You learned real quick that you either took a shower first thing in the am, or not at all unless it had recently been filled by the truck. The water would get uncomfortably hot over the course of the day.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
camperforlife
We have friend who had a trailer that the toilet was plumbed wrong and had hot water in the toilet. Under certain conditions you could flush and see steam. RV quality control at it's best.
downtheroad
dalenoel wrote:
We are in Lake Havasu City and temps have been above 120
I have to ask....why? (as in, why are you there?)
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Tom_Barb
drsteve wrote:
dalenoel wrote:
We are in Lake Havasu City and temps have been above 120...
120? As in degrees?
This Michigan boy would head down the road so fast it'd make your head spin.
You do any thing fast in that heat, your head will spin. 🙂
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
drsteve
120? As in degrees?
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
budwich
the tank usually has a "back flow" preventer valve to stop water from moving back from the tank thru the cold line. That valve could be stuck open so when only cold is selected, hot can flow backwards to the cold line.
Crambo
I'll check the outside shower. I'm running the water from the campground through a hose so not using the holding tank. I'm not a fan of cold water anyway so this just makes it better.
3oaks
Ivylog wrote:
or the outside shower valves are open.
My thought too.
If you have an outside shower and shut off the water at the shower head and left the hot and cold valves open, hot water from your water heater can mix with your cold water plumbing.
Passin_Thru
I lived in Yuma and summer T would be 119 every day with 122 for a high one day. Pool water was 85 and didn't cool you off much. Check the temp with a kids thermometer, you know the one you shove .......
dalenoel
We are in Lake Havasu City and temps have been above 120 so we have not turned the heater on in weeks. Water right out of the ground is warm enough to bathe and I like really hot showers.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
Tom_Barb
Most trailer water tanks are on the bottom of the trailer. right over the hot black roadway. kinda like free hot water.
Ivylog
Upgraded with a 08 HR Navigator 45’...
downtheroad
or....if you are using water from the campground through a hose...the water in the hose is getting heated by the sun/ambient temperature.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Turtle_n_Peeps
When you put water in a tank and the tank is inside of a hot trailer that water will be as warm as the temp surrounding the tank. Sounds like the water could be 90 to 100 degrees +.
Yes, the water will feel warm.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
