โApr-01-2016 09:10 PM
โApr-04-2016 07:18 PM
jefe 4x4 wrote:
Coplin,
The add-a-leaf is what broke. I have similar only they haven't broken.......yet.
jefe
DOITHARD wrote:
Nice set up! I like the light bar on your older, what brand?
โApr-04-2016 07:13 PM
Bedlam wrote:
Axle rating is based on the wheels offered with that model truck. The F250 came with 17" wheels and tires rated over 3000 lbs and the F350 came 18" wheels and tires over 3500 lbs. It's the same axle for the F250 and SRW F350 - It does not change until you go to the DRW F350. The difference in codes on your 2001 springs probably spec'ed it as with or without upper overload since you added your upper later.
โApr-03-2016 08:49 PM
pcoplin wrote:
I had my lance Lite 915 on a 2001 F250. It had add-a-leaf springs in the rear and a front leveling kit. I added an upper overload, rear sway bar, upper and lower Stable loads, and took an inch out of the front leveling kit. Ran it for a year like that. Handled great, especially after the sway bar.
I bought a new truck, a 2005 F350 Crew Cab. Went on one last camping trip to the Deschutes in March. I went to transfer over the rear Stableloads, and found this:
I got the old truck all cleaned up, broken AALs removed, camper tie downs, Stableloads, and Superhitch moved over to the new truck. The Crew Cab suits the extended cabover better. Also, the F350 springs are rated higher than the F250 springs, and with the Stabeloads hooked up it only sagged 1.5 inches.
โApr-02-2016 09:45 PM
โApr-02-2016 12:58 PM
โApr-02-2016 12:34 PM
Bedlam wrote:
pcoplin:
The F250 and F350 springs are the same other than the upper overload. What you see is the upgrades Ford did in 2005 verses your previous generation truck. The chassis and springs are actually stronger, the front end went to coil allowing tighter turning and the brakes are larger.
โApr-02-2016 12:19 PM
โApr-02-2016 10:45 AM
โApr-02-2016 08:58 AM
pcoplin wrote:Vinsil wrote:
Nice upgrade. ๐
Specs on the 6.0? Still love those!!!!
I like the crew cab look too.
Thanks. ๐ I was looking for a Dually Lariat 05-07 6.0/5R110, but only found two duallys, neither worked for me.
Got his one locally. It;'s in great shape. 2005 F350 XLT, 6.0/5R110. Engine stock, oil cooler slightly clogged though. I backflushed it a couple times and got it under spec, but I'm going to have to replace it. I'll do the EGR delete at the same time.
Heading out tomorrow for some camping! I'll call you for a tow if I blow head gaskets. Haha!
โApr-02-2016 07:11 AM
โApr-02-2016 04:19 AM
โApr-02-2016 03:22 AM
โApr-01-2016 10:57 PM
โApr-01-2016 10:40 PM
