Parking TT on sloped driveway
jrdbrn
My driveway has a slope left to right due to the height we have to build now in southern Louisiana. I believe it's a 24" slope across 20'. It's fairly significant in terms of long term storage I believe. Is there anything I should do when storing it? Products to help? I'd rather not rent a place to store it.
Talking about a Starcraft 20BH.
22 REPLIES 22
valhalla360
Nomad III
Nomad III
Assuming your estimate is reasonable, that means there will be around 9" between sides.
That's higher than I would like to go on blocks/boards. I might go with 3 2x8's, but that will only make up about 1/2 the cross slope. That should be fine for storage and packing use (not fridge)
If it's a permanent dedicated site for the trailer, you could pour a raised area of concrete specific for the trailer to get it level. There would be a drop off or steep slope just beyond but 9" isn't outrageous.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
SoundGuy
I find your post confusing as it would seem really unusual to have any driveway slope so much across it's width ... along it's length to the street, sure - but across it's width? :h However, if that's what you really mean and you're looking for a side-to-side leveling solution for your trailer I sure wouldn't be using plastic leveling blocks in this application as they'll quickly deteriorate from constant exposure to the sun. I use Lynx Levelers for side-to-side leveling when camping but at home I use 2 x 12 pressure treated wood under the low side tires and since our driveway slopes noticeably to the street a set of rubber chocks between each set of adjacent tires to absolutely prevent it from shifting in any way.
2012 Silverado 1500 Crew Cab
path1
troubledwaters wrote:
You don't need to do anything if you're not using it. Only if you want to turn the frig on does it need to be close to level.
And water keeps flowing but I would still put something under tires creating a slope of quarter inch a foot. Still shed water but not as steep.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
troubledwaters
jrdbrn
https://www.amazon.com/Camco-Leveling-Blocks-Hydraulic-44505/dp/B00480BWCI
Looks good to me
Dick_B
I like RR ties over cement blocks. Cut to any length you like.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Bobbo
I agree. Leveling blocks.
Bobbo and Lin
profdant139
Can you put blocks under the low-side wheels? We do that all the time when boondocking on rough ground.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
