Apr-14-2014 01:46 PM
Apr-15-2014 03:22 PM
myredracer wrote:
The weight of any factory options - 4x4, 8' box, super or crew cab, plus all the lesser ones (tow hooks, ex.) - will reduce payload capacity. What is shown on the sticker is not necessarily accurate and is for a base curb model without any options. For example, upon going to a scale, the payload cap. on our F250 is supposed to be 2701 lbs but is actually 1800 lbs and it's because we have 4WD, 8' box and super cab plus a canopy of about 200 lbs. That's about 900 lbs less than what the sticker on the door pillar says. It is what it is... Many swear that the sticker is 100% accurate tho. and can find themselves in a jamb. If you don't really need 4WD, don't get it. That's the single biggest eater of payload capacity.
The best thing you can do is fill your fuel tank up and go to a scale with just the driver and subtract the weight from the GVWR figure.
Apr-15-2014 01:11 PM
Apr-15-2014 12:44 PM
Apr-15-2014 12:41 PM
Apr-15-2014 12:35 PM
BurbMan wrote:
...........snip........
If the fresh water tank of the trailer is behind the trailer axles, you can actually reduce your tongue weight and increase available payload by traveling with a full water tank. ........snip.......
Apr-15-2014 12:26 PM
shorteelaw wrote:
But giving ourselves 100 extra pounds of payload would give us approximately 660 extra pounds to have in the trailer, right?
Apr-15-2014 12:09 PM
Apr-15-2014 11:44 AM
boosTT wrote:
There are a lot of people who are over their payload...
I wouldn't worry about pulling a bed cover to save 100 lbs. Now if you are 500lbs over the GVWR or over the axle ratings, I would start to be concerned.
I'm right at my max payload hauling an atv in the bed while towing my 19' travel trailer. My setup tows great using an ram 1500.
Apr-15-2014 11:42 AM
Apr-15-2014 10:43 AM
kaydeejay wrote:Francesca Knowles wrote:Francesca, small point but you will not find GCWR on any label on the vehicle as it is not a legally required number.
Per your max trailer weight: T'other figure that should be on your door panel is Gross Combined Weight Rating- "GCWR". That's the very maximum weight that the trailer/truck combo and all contents can weigh.
The ONLY place it will be found is in the Owner's manual (or on appropriate web-sites of course).
Apr-14-2014 09:13 PM
Apr-14-2014 08:33 PM
Apr-14-2014 08:19 PM
Need-A-Vacation wrote:Shorteelaw wrote:PUCampin wrote:Shorteelaw wrote:
I just looked and it's 1900... so if we add in the 150 pounds it gives for "free" from what I understand and then take away my husbands weight since he was in the truck at the time of weighing - that'd be more like 1750.... we have a 450 pound discrepancy... not sure where that 450 pounds could be weighing...
Just so you know, there is no 150lbs free. Previously, when curb weight and payload numbers were more vague, it often was the case. However since I believe 2006, the Tire and Loading sticker has been manditory, and is specific for that vehicle as equipped.
The Yellow tire and loading sticker states "The maximum allowable weight of ALL passengers (including the driver) and cargo not to exceed XXXX" This number is for your truck as it left the factory with factory options and includes a full tank of fuel. It is usally an odd number. Example, my Expedition EL XLT 4x4 with factory rear air and sunroof has a maximum allowable of 1672lbs
So if your tire and loading sticker says 1900lbs, then subtract your husband's weight, the cover (typical fiberglass is 100lbs), and anything else. 1900 - 300 - 100 = 1500 Any dealer installed or aftermarket items would also subtract from this.
I'm hoping the cover is 100 pounds - we will be taking it off and then that'd give us a little more payload. 🙂
Thanks for clearing up the 150 pounds. It was actually on this forum that I got that info a couple weeks ago so that was surprising. I guess the lesson is - don't believe much of what you read, haha.
Is the bed cover a cab high "topper"/cap, or just a bed cover (tonneau cover)?
If it is a cab high "topper", it is probably closer to 200lbs.
Good luck!
Apr-14-2014 08:14 PM
I got the 150 pound from several other threads on this forum in just the past couple weeks. But as someone else explained to me, that is how it used to be when they weren't precise with the info on the sticker. Makes sense.
Apr-14-2014 08:13 PM
Shorteelaw wrote:Old-Biscuit wrote:
Where are you looking up payload info? The information is consistent no matter what reputable website you look at.
What are the numbers on door jamb data sticker? I already answered that in another post.
GVWR of 7200# minus scale weight 5900# equals 1300# of capacity left. Yes - that's what I already said in my initial post.
5900# included your husband and EVERYTHING in vehicle. Yes again... that's what I already said in my initial post.
1300# minus your weight, minus anything you put in vehicle, minus any other passengers & their stuff........not much 'actual payload' capacity going to be left. It still leaves us with over 800 so I guess "not much actual payload" is extremely subjective.
That's the reality of real numbers vs mfg. published marketing numbers that have fine print/caveats such as:
**May vary depending on model, trim and/or powertrain. (We had looked it up based on exact model, trim, and powertrain)
**Weight of additional options, passengers, cargo and hitch must be deducted from this weight Yes I am quite aware and already mentioned that...
I've responded in red above. I'm not sure if you didn't read the majority of my post or any of the comments afterward but I think all you did was just give us a synopsis of what I already said.
