Nov-25-2014 09:14 PM
Nov-29-2014 08:42 PM
Nov-29-2014 07:55 PM
Nov-29-2014 07:07 PM
Nov-27-2014 12:47 PM
Nov-27-2014 07:40 AM
Nov-27-2014 07:16 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Nov-27-2014 07:14 AM
Reddog1 wrote:
If you are willing too max out your credit, live beyond your means, live pay day to payday, there has been lots of valuable information here. I also ask, what is your yearly income? Is this your only interest in life? Are you willing to dedicate your future on payments which include 18% or more interest?
Nov-27-2014 06:25 AM
ruthiebaby88 wrote:
Was at the dealer today and told that a 3/4 ton could carry anything less than 9.5 feet and not to worry about the weight. 'Everybody's doing it!'
Nov-27-2014 12:13 AM
Nov-26-2014 07:27 PM
ruthiebaby88 wrote:
With these heavy duty vehicles, is there anything in particular to watch out for that would tell you that it has been pushed harded than it should? I know a lot of people out there don't care about their tow ratings and work those trucks pretty hard. ...
Toad: 91 Zuke
Nov-26-2014 07:04 PM
Nov-26-2014 07:02 PM
wintersun wrote:
A diesel is great for towing 12,000 pound and heavier trailers. For camper use it is like having a Hummer to go grocery shopping. With a gas engine it does help greatly to have low 4.10 or 3.73 gears so the engine can spend more time in its power band without a lot of gear changes.
I would go with the new truck which is going to have air bags, ABS breaks, and often a 5-speed or 6-speed automatic transmission instead of a 4-speed. The extra speeds are overdrive gears.
It is also easier to find OEM and aftermarket parts for a newer truck, and that includes a situation where you need a water pump or alternator replaced when out on a camping trip.
I would be careful to note both the gears used (check using the VIN) and the capacity of the gas tank. Many older trucks have 26 gallon tanks while newer ones can have 36 gallon and the extra 10 gallons translates into more range before filling up again and when hauling a camper the MPG will be at its worst.
Diesel engines cost more to buy and twice as much to maintain and four times as much to repair. Easy enough to check the cost of a head gasket replacement or new set of fuel injectors for a diesel engine- it will be a shock but better to get it now than when you have a truck that needs to be repaired.
Diesels also require more frequent oil changes and fuel filter changes and need two batteries for starting. There are also far fewer places that can do diesel repairs which is again a factor when out on the road on trips.
Nov-26-2014 03:03 PM
Nov-26-2014 02:48 PM
Nov-26-2014 02:24 PM
jimh425 wrote:
Chevy's are strong than a Ford & especially a GMC? There must be a typo somewhere. 🙂 Aren't the GMCs and Chevys the same? What do you mean by stronger?
