May-19-2015 02:53 PM
CB
Channel 17Redneck Express
May-19-2015 06:17 PM
kohldad wrote:
Sure hope not for number 1 as that is the way my Lance 815. Standard 20# bottle standing up below my fridge. Since propane is heavier than air, it will sink away from the fridge.
For number 2, my furnace is located under my wardrobe cabinet. Just make sure the bottom of the cabinet is sealed so nothing can fall down onto the furnace. There is also a minimal space requirement around the furnace so you need to make sure you have the required space.
Biggest concern with adding the basement is raising the COG which could have a large impact on handling, especially if you travel off the beaten path.
CB
May-19-2015 06:08 PM
May-19-2015 05:24 PM
May-19-2015 05:09 PM
May-19-2015 04:22 PM
jimh425 wrote:
The propane tank has to be vented to the outside and if a normal tank has to stand up as well. I think that eliminates both of your choices.
I would look into where you can box a compartment and put the tank there wherever "there" is. After that, you can run the propane hose to your appliances.
CB
May-19-2015 03:15 PM
May-19-2015 03:01 PM
