plastic radiator crack, Burb
LVJJJ
Got a 94 K-1500 Suburban, only 144,000 miles but has developed an antifreeze leak via a 3" crack in the driver's side plastic rad side tank right around where the upper oil cooler line screws in. I can get a new rad for $185 from NAPA here in town, but have heard about plastic tank repair kits. Those things work and hold up? Is probably better to replace the radiator realizing that a failed patch wouldn't be good towing in the desert. Any thoughts, experiences with the patch kits?
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
19 REPLIES 19
kevden
I would replace it with an all aluminum one. Why rely on plastic end tanks with gaskets when you can have a welded one piece design for around the same price? Check if you have oil and/or transmission cooler lines going through the radiator before you order one.
2012 Keystone Outback 312bh
2003 GMC Yukon XL 2500 4X4 Quadrasteer
2010 VW Routan
2007 Chrysler Pacifica AWD
SidecarFlip
Time for a new one. Modine makes probably 90% of all automotive radiators now and all are plastic tanked and all die after a while. New only.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Lwiddis
Twenty-four year old radiator wouldnโ€™t have other weak spots? Replace!
thomasmnile
Not a Suburban, but the OEM radiator in the wife's 2000 Camry sprung a leak in the top tank 3 years ago. My replacement options were a new radiator for $500 from Toyota, or $110 from the local NAPA store. Opted for the NAPA replacement, installed it myself and it has been fine since. Never considered attempting a repair, though NAPA had a repair kit. The counter guy persuaded me that replacement was a better plan.
okoboji_fan
It cracked cause it wore out replace it with a new/rebuilt one and you get a warranty we have a couple of 90s era chevys and if we get a 150-180 k on a radiator were happy. There's not much to them
