Assuming you have a 30AMP SHore Power Cable that looks like this...
Plug this 30A SHore Power COnnector into a RV30A-15A long "dogbone" type adapter (WALMART). The adapter will plug into one of the 120VAC 20A Receptacles on the generator front panel.
This is the RV30A-15A typical adapter to use.
I use the 2KW Honda Generator for powering up my off-road POPUP. You need to have a generator strong enough to power up the trailer converter/charger unit. You can find the power requirements by listing here or on GOOGLE.
Without knowing anything about your trailer I am also assuming you probably do not have a smart mode charging technology converter/charger unit. With a smart mode charger you can re-charge your deep cycle in a short three hour time generator run time so you can immediately use the battery again. With a single mode type converter/charger on board will take a min of 12-13 hours to re-charge your deep cycle battery to its 90% charge state so you can use it again. If this is the case you may want to bring along a smart mode battery charger like the Black and Decker VEC1093DBD smart mode portable battery charger and plug this into the generator to re-charge your deep cycle battery in the short three hour time frame.
12-13 hours is a long time to have to run your generator and most camp grounds will not allow you to do this. Most camp grounds only allow just a couple of hours in the morning and maybe three hours in the early evening to run your generator at the camp sites.
Roy Ken...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
