When we camp off the power grid for extended times it looks like we consume around 250-300WATTS per day of battery power..
Our game plane is to run all of the 120VAC items we want to run from an INVERTER and all of the 12VDC items we want to run direct connected to the battery bank. The big drain occurs between 8PM and 11PM and with our 255AH battery bank we will see it drop down to its approximately 50% state of charge around 8AM each morning. This is when we run our 2KW Honda Generator to recharge the battery bank back up to its 90% charge state in a three hour run time using smart-mode charging technology. Once we get them back to 90% then we can do this all over again the next day/night run off the batteries.
We actually run just about everything we do at a regular electric site except no air conditioner or high wattage microwave use.
Using the solar panel during the day would charge the batteries up just fine. I'm thinking for what you are wanting to do 120WATT solar panel setup would probably be enough. Using the small 30Watt solar panels guys is wasting your money... You have to store the solar energy in batteries to be able to use them at night so why not just have a battery bank big enough to do what you want to do and then re-charge your battery bank to their 90% charge state using solar panels all day long. I still would want to have a generator along with me however- You will not always be able to use solar panels - might be cloudy for three or four days in a roll...
I would think getting all setup using batteries is the first priority to be "successful" and then supplement the re-charging of the batteries using solar panels during the times when the sun is out strong. You may eventually get enough re-charge to skip many days of generator use.
Batteries and Generator will always work for you. You don't need a very big generator - just big enough to run your on-board converter unit and let that re-charge your batteries. We are super successful doing this with our setup... Having solar panels is icing on the cake...
Just some of my food for thoughts on this based on our camping off the power grid experiences...
Its all in the planning...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
