Apr-25-2017 05:35 PM
Mar-16-2022 06:07 PM
Mar-16-2022 05:24 PM
Mar-16-2022 05:10 PM
LastChance4us wrote:
I had this problem and research it to find the true root cause. Remove the cover and carefully inspect the circuit board mount. I found that moisture is getting in between the circuit board and it’s plastic mount. The moisture sits right at the terminals that are the on off switch connector. I cleaned it, dried it and put a thine careful bead of sealant around this plastic rim and Vaseline on the terminal to resist moisture.
Mar-16-2022 01:50 PM
Apr-26-2017 05:25 AM
Apr-26-2017 04:14 AM
ScottG wrote:
Is it a common toggle switch?
Apr-25-2017 07:54 PM
Apr-25-2017 06:44 PM
Apr-25-2017 06:09 PM
Apr-25-2017 05:57 PM
