Problem # 2 Hot Water Heater
nimblewill
I have an Atwood G6A-Seven hot water heater in my 2002 Jayco Hybrid. It lights very easy but the burner only stays on for 2 or 3 minutes before going out. Sometimes when I turn it from "pilot" to "on" it blows the pilot light out but every time the burner quits the pilot goes out.
Very Frustrated.
8 REPLIES 8
spud1960
We are having the same problem,did you resolve this?
nimblewill
thanks. I will check it out and see what happens next.
enblethen
Thermal couple must be directly in the pilot flame.
Most are a weak orange.
Winterizing valves in correct position water should flow through tank to faucets. Could open the pressure reief valve to see if water comes out with pump on or city water connected. You will have to drain water out to re-establish air in tank.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
nimblewill
enblethen wrote:
There is water in the tank!
Verify that the thermal couple is directly in the flame. Replace thermal couple.
I replaced the thermocouple. Should the pilot flame be orange or blue? I cleaned the pilot assembly and the flame got smaller but bluer. now the thermocouple is not directly in the flame. No change in amount of time burner burns. I'm really new at this so how do I know whether or not there is water in the tank. All the valves seem to be open and I have turned on the hot water lines.
Chuck_S
Spiders love to nest in LP jets. Carefully clean out the jets with something soft, not steel.
-- Chuck
'06 Roo 23SS behind '17 Expedition out of Richmond
Our Photo pages
enblethen
Bud
USAF Retired
Pace Arrow
nimblewill
Thanks. I cleaned the pilot assembly and am getting a tighter bluer flame and the pilot burns longer but it still goes out when the burner goes out after about a minute. I check the rest of the things listed.
2edgesword
Here are some of the things Atwood suggest as possible cause of burner not remaining on and solutions:
Improper gas pressure -- Set inlet pressure to a minimum of 11? W.C.
with two or more appliances running
Improper air adjustment -- Adjust main burner air shutter approximately 1/4 open
Partial blockage of main burner -- Remove blockage
Partial blockage of main burner orifice -- Clean or replace orifice
Flame spreader misaligned--Re-align spreader or replace main burner
Blockage in โ€œUโ€ tube --Remove blockage
Poor gas supply -- Replace gas supply
Exhaust grille blocked --Remove blockage
Improper main burner alignment --Re-align main burner, main burner
orifice holder and gas valve
