Proflex removal
TECMike
What are you using to remove Proflex that has dried on a trailer joint. The dried Proflex is about a year old.
7 REPLIES 7
CavemanCharlie
I have to admit I've never heard of "proflex"? I thought that was a home gym built out of big rubber poles.
aarond76
Does this proflex caulking turn hard as a rock? I have some caulking on my camper that a previous owner did and its like cement now.
trail-explorer
I've used Bug and tar remover, but it's time consuming to clean the ProFlex
Bob
TECMike
Thanks so much, folks!
Mike
AtomicChicken
When I called Geocel about it a year or so ago they recommended mineral spirits and that seemed to work fine.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
Mark_Heisler
Last time I cleaned some off I use Mineral Spirits on a rag it worked great.
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
daystrom
ProFlex is a real pain to get off. The best thing I have found is to soften it up with WD40 and use a plastic scraper to scrape it off.
2012 Crossroads Zinger ZT26BH
2012 Ford F350 Lariat 4x4 6.7L PSD SRW
11,500 GVWR, 3522 lbs of payload
