โMay-03-2013 10:50 AM
โMay-03-2013 06:58 PM
DutchmenSport wrote:
Right after we purchased our Springdale, I was filling the black tank to flush it out. I have this round thing that slips in the toilet valve (bottom) and keep it from closing so the water will continue running. Well, I got carried away and forgot about the water running, and the wife started yelling ... WATER! WATER! WATER! Sure enough, the toilet overflowed and water running all over the floor.
We got it cleaned up, but unfortunately water also leaded through the walls, under the floor and into the underbelly where it pooled. Yuck. How do you get that out?
Got the trailer home and I used a screwdriver and punched one hole in the fabric-cloth-rubber underbelly "thing" and water started pouring out. I left it that way for an entire day until nothing dripped any more.
I then went inside the camper and took 2 of the floor vents for the furnace off, twisted the metal conduit so hot air would blow under the floor, and then placed heavy pillows on the top of all vents so the air was forced under the floor.
I cranked up the furnace, opened all the windows, and let it run for about 6 hours full throttle... OK I used up some propane. But with all the heat blowing under the floor (and the underside looked like a baloon ready to pop), it dried out completely. Also, I found every tiny place where air was blowing out from under the underbelly, marked it, and later went back and sealed up those spots.
The air blowing through the insulation like that, dried everything out, bone dry. I then took some gorilla type tape and simply taped the hole back up where I punched through the liner. Never had another problem, and I learned to always attend the toilet when breaking camp!
โMay-03-2013 03:30 PM
โMay-03-2013 02:23 PM
โMay-03-2013 02:11 PM
โMay-03-2013 01:05 PM
โMay-03-2013 12:57 PM
Francesca Knowles wrote:
I wouldn't hesitate to drill some drain holes- if there's water in there you need to get it out PRONTO. Such holes can easily be patched or, better yet, plugged with a removable nylon cap (in case more water accumulates).
You of course need to locate the source of the leaks if possible- but since you don't know how long the water's been there, you can't know if you even still have a "leak" problem.
If the rig was mine, I'd find the lowest point, drain it, and watch for more water.
โMay-03-2013 12:27 PM
โMay-03-2013 12:12 PM
โMay-03-2013 12:07 PM
โMay-03-2013 11:35 AM
โMay-03-2013 11:22 AM
โMay-03-2013 11:19 AM
