โApr-15-2019 08:10 AM
โApr-16-2019 09:13 AM
Emily_Eisenman wrote:Maybe look closer. There might be a capped tee in the black pipe if lucky, but were quick-connects common back in '92?. We had a tee on a previous TT. Problem was, it was near the front of the TT but our entry door and kitchen was at the rear. I bought some long propane hose and tie-wrapped it to the black iron propane pipe and installed a quick-connect at the rear.
Unfortunately there is no port or connection under the trailer.
โApr-16-2019 08:55 AM
โApr-16-2019 03:41 AM
Chris Bryant wrote:
Was your motor home lp hookup high pressure, using the 1lb bottle threaded hookup, or was it a low pressure quick connect. The low pressure can easily be added to your system, the high pressure can be added at the cylinders, but itโs a bit of a kludge.
Nice Airstream, btw.
โApr-16-2019 03:21 AM
โApr-15-2019 06:33 PM
โApr-15-2019 05:36 PM
โApr-15-2019 09:48 AM
โApr-15-2019 08:53 AM
โApr-15-2019 08:21 AM
