May-05-2014 08:02 AM
May-08-2014 10:59 AM
AirForceAngler wrote:Mkos1980 wrote:
Once the tank is off it still hiss/ spitting out the hose from the regulator.
You may have bad switchover valve if it is a constant hiss. Do you have the bottle valve closed on the "empty" bottle? empties, but that's about it.
May-08-2014 10:55 AM
Mkos1980 wrote:
Faulty regulator?
May-08-2014 06:43 AM
May-08-2014 06:16 AM
May-07-2014 10:53 PM
Mkos1980 wrote:
Once I am drawing off a good tank with the arrow pointed to the good tank, should I have some leak out the other side when I disconnect my empty tank? I was having an issue this weekend and noticed when I pulled the empty tank off I was getting a small amount of propane coming out of the hose even though the switch was over to the good tank. Faulty regulator?
May-07-2014 09:23 PM
May-05-2014 06:46 PM
12thgenusa wrote:AND the first tank to be opened should be on the side the indicator is pointing to.
An obvious point but maybe missed by some is that both tank valves must be open in order for the auto change over to take place.
Reese Dual Cam Straight Line HP Sway Control
May-05-2014 03:08 PM
May-05-2014 10:22 AM
May-05-2014 08:32 AM
May-05-2014 08:28 AM
May-05-2014 08:22 AM
May-05-2014 08:16 AM
djgarcia wrote:
Propane tanks-
What is purpose of the middle position? When should the middle position be used?
