ProPride Stinger and F350 Dimensions
PacNWChris
So, I try to find the answers to my questions BEFORE posting here, but with these, I haven't had any luck.
It looks like the stinger on the ProPride is 2" x 2" for the hitch receiver - correct?
What is the hitch receiver size on an F350? Is it also 2" x 2" or is it 2.5" x 2.5"? In looking at footnote #3 at the bottom of page 3 of this link ...
http://www.ford.com/resources/ford/general/pdf/towingguides/14_superdutypu_sep11.pdf
... it makes it seem like it's got the larger size. So using the adapter would reduce the capacities - correct? (Of course, the truck is still more than capable of towing my TT)
As always: THANKS!
2014 F350 Platinum 6.7L Power Stroke
2015 Salem Hemisphere Lite 282RK
ProPride 3P Hitch
9 REPLIES 9
mhardin
My 2013 F-350 has the 2.5". I have a Hensley and use the adapter. No reason I can think of to get a bigger stinger. It does make it slightly more difficult to align the holes, but nothing to worry about.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
Lantley
Why I don't imagine anyone towing with any other vehicle than their own. The adapter gives you flexibility to tow with any capable vehicle with a hitch.
Could be an issue in a pinch.......you know Murphy's Law
lbrjet
I would get the 2.5 from Sean and be done with it. Why use the insert when you don't have to?
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
PacNWChris
Yeah. It is 2.5" square. I just got differing installed ... it took me about 4.5 hours. I think I can live with the 2" adapter in there for now.
ProPride 3P Hitch
Heap64
The newer F250 and 350 are now 2.5" as well. Of course you can use the spacer to go down to 2" but that adds an extra amount of slop or play. Call Sean he would probably swap out the stinger if you pay the shipping.
James & Kim from Central Illinois
2012 Ford F250 XLT CC SB 4x4 6.7, ARE Topper and Decked Draw System
2013 Arctic Fox 25Y (1250lb tongue weight with mods)
Blue Ox Sway Pro 1500 w/Reese Titan Weight Dist Shank
mbutts
My 2006 F-350 is 2 x 2.
Mike Butts
DW+DD+DS+Poodles
2017 Forest River Forester 3011DS (first MH!)
Previously 1999 Coleman Santa Fe pop-up, 2007 Kodiak 23SS hybrid, 2013 Sunset Trail 29SS travel trailer
Jframpey
Oops, after rereading your post I understand what you were asking... I have a Chevy 2500... It has the 2.5" receiver - I can't speak for Ford.
Go look at a truck on the dealers lot that is similar.
PacNWChris
Jframpey wrote:
The standard ProPride receiver is 2" X 2", but you can request an optional 2.5" X 2.5" (no additional charge)
I got the bigger one so I could tow without the adapter inserted... Takes out the "rattle".
Joe
Okay, cool. So I'm guessing that means the F350 *is* in fact 2.5".
I've already got a ProPride hitch system in transit to me, but I didn't even think about the possibility of the different size. I'll have to use the adapter until I can figure out how to get the 2" swapped for the 2.5".
Thanks!
ProPride 3P Hitch
Jframpey
Joe
