Jun-11-2014 10:16 AM
Jul-01-2014 06:57 AM
Skid Row Joe wrote:
Sometimes the dealer knows best - I would listen to John - he was brought-up in the car business for over 40+ years.
Jun-30-2014 09:45 PM
JALLEN4 wrote:brulaz wrote:JALLEN4 wrote:
The modern vehicle is better built and does require less maintenance.
Many dealers do suggest more frequent maintenance intervals than the factory manual. This is simply because they see first hand the problems encountered when the service intervals are lengthened by the manufacturer in attempting to convince the consumer the vehicle is cheaper to operate
So what are you saying? Modern vehicles require less maintenance, BUT not as little as the manufacturer's recommend? Increased service intervals are bogus, despite all recent improvements in oil, cooling fluid, and so on?
Frankly, I would trust the manufacturer's recommendation over the recommendations of most dealers that I've dealt with.
You can certainly choose to use any recommendations and for most people they are going to believe the manufacurer before the dealer. A little research though will find several cases where following the manufacturers schedule resulted in "sludged" engines and other problems in as little as 30,000-50,000 miles. Lexus, Toyota, BMW, and MINI are a few that have had severe problems often contributed to extended oil change intervals.
Jun-18-2014 09:12 AM
Jun-18-2014 04:48 AM
Jun-17-2014 09:09 PM
monkey44 wrote:
Gotta tell ya one thing tho', when you replace your air cleaner, and then go in and get an oil change, and the dealer recommends a new air cleaner because yours is 'dirty' ... Kinda makes ya wonder?
Jun-17-2014 03:47 PM
Jun-17-2014 01:45 PM
Jun-17-2014 12:58 PM
Jun-16-2014 05:12 PM
Cummins12V98 wrote:B.O. Plenty wrote:I can't speak for everybody but I know AC DELCO only makes one grade...Cummins12V98 wrote:I've worked at several dealerships. We never carried anything but the OEM factory oil filters. Dealers have to warranty all the parts they use. This is why they insist on OEM parts. If it was for a vehicle we didn't sell then they would get an aftermarket filter from NAPA for that particular vehicle, but they never stocked anything but factory parts for anything they sold. I doubt if any dealers are any different.
Something to think about. The factory dealers usually have two grades of oil filters. Guess what, for the free oil changes for life or their specials you are getting their bottom of the barrel filter.
If I had any of these oil changes done I would pay the difference in filter costs to get their best!
B.O.
B.O.
Did I say they were NOT OEM? I said two GRADES!
Jun-16-2014 04:34 PM
B.O. Plenty wrote:Cummins12V98 wrote:I've worked at several dealerships. We never carried anything but the OEM factory oil filters. Dealers have to warranty all the parts they use. This is why they insist on OEM parts. If it was for a vehicle we didn't sell then they would get an aftermarket filter from NAPA for that particular vehicle, but they never stocked anything but factory parts for anything they sold. I doubt if any dealers are any different.
B.O.
Jun-16-2014 03:26 PM
Jun-16-2014 03:12 PM
Jun-16-2014 01:32 PM
JALLEN4 wrote:monkey44 wrote:
Another issue -- dealers at one time had plenty of work keeping up with the maintenance on vehicles they sold. NOW, most do not have the same requirements, no points, plugs, rotor etc every 'xx' miles ... so, once the truck sells, we now have 100,000 mile plugs, electronic ignitions, and most of the general maintenance items are now absent.
What's a dealer to do - well, make up some 'check and adjust' periodic maintenance so it can keep its mechanics busy ... brakes now last twice or more as long, and other items that once wore out, don't. So, here we have mechanics with nothing to do ... and equipment that costs a fortune to buy and maintain.
Nothing against good mechanics here, we need them when we need them -- but to schedule periodic maintenance to 'look' at things that 'ain't broke' makes no sense --
That is really not entirely true. The modern vehicle is better built and does require less maintenance. On the other hand, the number of new vehicle dealerships has decreased dramatically, the number of vehicles in operation has increased dramatically, and the average age of vehicles in operation are far older requiring more work. In addition, the time for repair has increased with the advent of computerized controls and more complex diagnostics. Good shops are not standing around looking for something to do and the dollar volume they do is far higher than 30 years ago.
Many dealers do suggest more frequent maintenance intervals than the factory manual. This is simply because they see first hand the problems encountered when the service intervals are lengthened by the manufacturer in attempting to convince the consumer the vehicle is cheaper to operate and less time consuming. In many cases, the manufacturer has shortened service intervals from the level of just ten years ago because of these problems.
Like many other things, this can be carried too far by certain dealers. But simply because theyrecommendationomendation does not mean they are out to take advantage of the consumer. Anybody who flies a plane would be quick to realize that visual checks are important and are a necessary part of pre-flight. Seldom to vehicle owners take the time to actually inspect their vehicle when they drive it and rarer yet is actually putting the vehicle on a lift to do the job right.
Jun-16-2014 12:09 PM
