Pros and cons.....
campermama
Between 14" wheels and 15" wheels on a travel trailer???
Thanks!!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
12 REPLIES 12
Lynnmor
BlueridgeCoachmen wrote:
I always figured they put that size tire on for a reason.
Yep, and the reason is that smaller is cheaper.
rbpru
You can do what you want; but remember, the designers of the TT and TV build their product to perform around the materials they have selected. That includes the tires.
Marginal or not those are the materials that were selected to do the job.
Of course if you are the expert and are compelled to up-grade there is nothing stopping you, except perhaps the manufacturers warrantee.
Almost everyone upgrades a few TT or TV items; because it just makes them feel safer, better, etc.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
time2roll
Most all tire wheel combinations from OEM are marginal at best.
Bigger trailers will have bigger tires but still very close to the max rating.
BlueridgeCoachm
I always stay with what size the factory put on , Same on the tow veh. I always figured they put that size tire on for a reason.
2016 Coachmen Catalina 223FB, 26ft // 2016 Ford F150 2WD Super Cab 3.5 EcoBoost Trailer Tow Pkg. 355 eLock rear diff.
Sean_Boburk
Unless you put a larger diameter tire on, a 14 and 15 inch rim will turn the same speed...
If you put a noticeably larger diameter tire on...you will need to adjust the hitch, and may have some other problems (clearance between tires, brakes will wear faster, stabilizer will be further extended....less stable...)
Sean
2011 Flagstaff 29SKBS
2010 F-150 4x4 5.4L
2011 camping days=23 in 9 locations
2012 camping days=4 in 2 locations
atreis
Absolutely no disadvantage to going bigger if they fit.
2021 Four Winds 26B on Chevy 4500
penguin747
As noted before 15 is better choice just as far as finding a replacement in small towns just in case u ever had to.
wanderingbob
Ain't a whole lot of difference . Fifteens do turn slower , either would not be a deal breaker . As for on the road availability most Wal-Marts . Tractor Supply and many more will have fourteens , six ply mounted on galvanized wheels for about $110.
jmtandem
Fifteen inch provides more choices. And if you can go with 16 inch tires so much the better as there are more non ST choices.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
deltabravo
15" tires - more tire choices. Also more likely to find a tire in a small town if you have a problem where you need to get a new tire.
Tequila
larger, the better. Larger tires spin slower, run cooler, better clearance
prichardson
My 2 cents. If you have a choice; go with 15". You will have more options in tires.
