Prropane water heater (electric start)
dodah
Well here it is.....
Lite the propane heater and it started and I kept busy with other projects and a noticed the heater had stopped a short while after.
tried to re lite and noticed that the red light at the switch over the sink was not on.....
Have i killed the heater or is there a fuse or reset switch I am not seeing ???
Need your help on this one folks
Thanks
7 REPLIES 7
dodah
Hello all
Found that reset button on the front of the water heater and problem was solved.....
Still not sure what make the heater is as i can find no manufacturer,s name
Thanks for all your your help
dodah
Thanks for this info . I will check this out and let you know how it works out
beemerphile1
The red lighted switch in both of mine is only on when the heater is lighting. Once the heater is lit and operating the light goes out.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
coolestdude
Mine has a reset button behind a round piece of rubber up and to the left of the drain plug. Also mine is a Suburban water heater
Happy Trails!
Old-Biscuit
Check water coming out of tank....is it hot?
If really hot then high temp t-stat may have operated (opened) because normal t-stat failed
May be able to reset by pushing small button on t-stat (after temp has cooled off)
What Brand/Model?
downtheroad
Start with the simple first:
Make sure the water heater tank has water in it.
Make sure the propane line does not have air in it...bleed the line by lighting the kitchen stove.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
enblethen
Red light would come on if water heater faulted for some reason.
Are you sure it quit working or got up to temperature and the thermostat shut it down?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
