Pure sine wave inverter suggestions?
Geewizard
I'd like suggestions for a 1000W pure sine wave inverter.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
37 REPLIES 37
Geewizard
I need to charge an electric dirt bike. Its charger is AC only and I will pay the extra for a pure sine wave inverter. I had a MSW inverter for my microwave and it really did not like the MSW.
My CPAP runs from 12VDC.
Thanks all.
naturist
Kayteg1 wrote:
{snip}Than per my experience, there is no need for pure sine on RV.
Have been using modified wave for over 20 years just fine.
True that most things work fine on MSW, but some things donโ€™t. And many of the things that donโ€™t can be damaged on MSW. Electric blankets, for example, and CPAP machines. I have several photographic studio lights that are known to burst in flames with MSW inverters. While not camping gear, they do serve to notify us all that what you need to buy depends on what you seek to power.
naturist
I have a 2200 watt Giandel PSW inverter that works well. 3 year warranty, only 8-9 watts when idling.
time2roll
GoPower has worked well for me. I have just the stand alone inverter. No integrated charger or transfer switch.
Xantrex died way to early.
Kayteg1
This is what I was talking about
corvettekent
I have been using this Samlex inverter for five years and it has worked great. I know that you asked for a 1000 watt but you can get a 2000 watt for just a little bit more.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
WNYBob
Samlex Inverter, a little pricey but a real pure sin wave Inverter.
Kayteg1
I bought 3000 W pure sine on ebay for less than $100.
Lot of people are skeptic about cheap Chinese stuff, but guess where is manufactured the expensive stuff, even when it has "assembled in USA" label?
Only microwave oven seems to have lower output and occasionally have to give it extra time.
Than can't say if that is due the wave, or dropping voltage.
