May-15-2021 03:11 PM
May-17-2021 01:46 PM
mellow wrote:
I will leave this here: https://www.truckcampermagazine.com/camper-tech/installing-super-singles-on-a-ford-f-450/
May-17-2021 12:47 PM
cptqueeg wrote:
In theory, btwn sand and snow super singles seem to be a good fit for me.
May-17-2021 12:41 PM
May-17-2021 12:38 PM
May-17-2021 12:35 PM
May-17-2021 11:28 AM
Avid Fox wrote:
"Don't you run out of room btwn the DR tires when aired all the way down?"
You would if you didn't space them correctly. 285s need wider rims than stock also, which use 245s. Yeah, there would be some expenses... prob about $5000.
Maybe super singles are not such a bad investment after all.
May-16-2021 05:26 PM
May-16-2021 05:02 PM
May-16-2021 04:33 PM
May-16-2021 04:32 PM
May-16-2021 03:52 PM
NRALIFR wrote:
I did go over the front jack mounting plates and made sure they were secure, and improved them a little. They already had some sheet metal backing plates on the inside, and self-tapping bolts that went through the plates. I made sure they were tight, and put some nuts and big fender washers on the bolts. There really wasn’t enough thread engagement between the bolts and the backing plates for my taste.
May-16-2021 03:46 PM
Avid Fox wrote:
I don't think a widening adapter on the front brackets would be much extra stress, unless it was abused. They are already wide enough to torque themselves off and break the corner supports if stressed badly enough. An extra 2" per side likely requires the same amount of care when down as the OEM parts.
It would be awesome to float over the sand in a camper like a sand rail, but the noise on the other 95% of road driving would be super annoying.
For me, ideal tires for a dually would be 285 sized, load range G, working air range from 20-110psi, and with a BFG KO2 type tread. But, they don't make it... Probably for technical or engineering reasons.
May-16-2021 03:26 PM
May-16-2021 02:52 PM
NRALIFR wrote:
Adding a little width to the swing-out dually brackets can be done easily.
The F450 pickup bed width is a few inches wider across the dually fenders than the F350’s, so I had to extend my swing out brackets. I used 3” wide flat stock, 3/16” thick, and sandwiched the jack and bracket between two layers.
Don’t extend them too much, or you could hit the cab with the jack when you swing them in.
Mine end up pretty close to the front tiedowns, so I have to center the camper in the bed carefully.
May-16-2021 02:50 PM
