โJun-28-2015 01:34 PM
โJul-02-2015 07:18 AM
FishOnOne wrote:Cummins12V98 wrote:rhagfo wrote:estesbubba wrote:Bionic Man wrote:
You know that there are some people on here that will argue that it is easier to change a tire on their tow vehicle because there is a better design on the (insert brand here) lugs.
You will never convince the troller that anything, especially RAM is on par with a beloved Blue Oval, so why try?
Exactly. I recently went to a diesel clinic at my dealer that has a top 3 Ram dealer in the nation, a #1 Ford truck dealer in the nation, plus a Chevy dealer. After the presentation and questions we all went into the shop and they had diesels from each where people could ask questions. Looking at them all side-by-side:
- The Ram had the most room to work under the hood
- The Chevy was a little more crowed
- The Ford was a freakin' cluster-f...
Of course someone on here has a cousin who's ex-wife's ex-husband knows a guy who works on diesels and said that Ford has the most room.
Ford DOES have the most room!! Once you remove the cab!
BAM!!!!!!!
I sorta illuded to that earlier.
BAM!!!!!!! Did I post the wrong brand. :B
โJul-02-2015 06:34 AM
BAM!!!!!!!
โJul-01-2015 08:04 PM
BAM!!!!!!!
โJul-01-2015 07:50 PM
โJul-01-2015 07:46 PM
โJul-01-2015 07:44 PM
โJul-01-2015 04:19 PM
โJul-01-2015 03:16 PM
โJul-01-2015 12:29 PM
Cummins12V98 wrote:goducks10 wrote:
I had a 1994 Ford Ranger and when I didn't do the oil change Oil Can Henrys did. !98,000 latter and no issues. I never once changed the oil on our 03 Accord. 130,000 and no issues. I have been doing oil changes on my 12 Ram CTD up until the last few. If something happens to it that's what the warranty's for. As bad as everyone makes all dealers sound, some are decent. My 12 is known for oil dilution because of regens. So you end up with more fluid in the oil pan after x amount of miles. It calls for 12qts of oil. The common sense thing to do is put 11qts in so after 3-4-5000 miles you don't have an overfull oil pan because of dilution. The dealer I take mine to only puts 11qts in. Works for me.
He puts 11 quarts in because he pulls the drain plug and as soon as the flow stops the plug goes back in and only 11 quarts are needed. I let my 11 drain overnight and would add 11 5/8 quarts and it would be on the full mark. The pan/plug design does not allow for complete drainage.
Lots of people think they are making oil with fuel dilution but the fact is they are just overfull because 12 quarts have been added.
โJul-01-2015 08:37 AM
Cummins12V98 wrote:FishOnOne wrote:rhagfo wrote:Cummins12V98 wrote:Bionic Man wrote:
This is turning into another example of how forums like this are by far the exception to what happens in mainstream America.
I would be willing to venture a guess that less than 10% of people change their own oil in their cars. And it is probably MUCH less than that. I am not sure I personally know anyone who changes their own oil. And unless I go on a Fish story, where a friend of an aquainatance of a neighbors dogsitters cousin, I have never heard of a true problem caused by an incompetent tech. I know they are out there, but they are far from rampant.
I have 4 vehicles plus a couple of boats in my "personal fleet" of vehicles. I change the oil in my fishing boat, but nothing else. The worst thing that has happend in having someone else change the oil is Grease Monkey didn't correctly reattach the air dam on my wife's 300 one time. Quick trip back to them, and it was fixed.
That is 25 plus years of driving, who knows how many cars.
More power to those that have the time and inclination to do their own oil changes. But having someone do the service for you is far from the riskiest thing you will do in the day.
My Daughter worked art Walmart changing tires and oil. She is a smart gal but the stories she told me about the Monkeys she worked with were amazing. I personally know someone that had their oil pan replaced by Walmart because they stripped the plug.
I like to know my vehicles inside and out. Get underneath it and look it over once in a while like when changing oil.
I agree 100%!
As a kid I worked on my own vehicles to save money, now I work on them as therapy! ๐
I agree too. I actually enjoy changing the oil on our vehicles.
Note: Vehicles that require standard methods to perform an oil change that is.
Dude this is getting old! Do we need to start discussing what needs to be done to some trucks to have the engine worked on?
I proved it is not a big deal to do a oil change on a 13 and newer RAM using the method I described. It is something that can be done while the oil is draining or are you one that drops the oil then without it finishing draining the plug goes in and then the oil?
I guess I should do a YouTube video of how quick and easy it is to R&R the air intake.
But instead I will leave it to the RAM owners that do appreciate info that makes the oil change a easy task now.
Two hose clamps one bolt and a spring clamp, gee I should sell my POS before I have a breakdown worrying about my next oil change.
โJul-01-2015 08:27 AM
Cummins12V98 wrote:up2nogood wrote:Cummins12V98 wrote:FishOnOne wrote:
Excuse me while I let you fan boys pass the Kool-Aid around! :W
Well Fish I am happy for you that you have a truck that the oil filter is easier to change and has nice mirrors.
But for me the extra 10 minutes it may take to change my oil is a minor inconvenience and I think I proved with my post it's really not a big deal to change the oil on a 13-15 RAM.
I think you are being kind here with the ten minute extra. I have to disagree, I've changed the oil three times now on my 2014 Ram, and although I'm getting better at it, and yes I have done it the way you showed, thats nothing new when changing the oil on these new Rams. At best its still a pita .
So you removed the steel pipe at the top? It is easily a 10 minute job the way I did it.
"Nothing new" ?
Please show me where anyone has posted the way I did it. Everyone removes the hose down low and fight getting it re connected. Or they go thru the fender well and there is no way that is a easy job.
โJul-01-2015 05:08 AM
blofgren wrote:
Thanks very much for posting; I really appreciate the information. I guess I got blindfolded into removing that lower clamp by reading on the issue and didn't look at the big picture. I just looked at my truck and it does indeed have the same configuration so I'll try that next time. It looks like there is some sort of orange sealant in that hose; did you have any trouble getting that apart?
I do agree with others, though that this is still a PITA procedure compared to others. My 6.0L Ford was much easier to service. I think though with some time the Ram will get easier; I'm definitely not getting rid of it over this! I still love it more every time I drive it.
On another note, have you posted some details/photos of your new Mobile Suites yet or did I miss it? :B
โJun-30-2015 09:01 PM
โJun-30-2015 08:51 PM
