Sep-09-2019 06:36 AM
Sep-13-2019 08:57 AM
ShinerBock wrote:
^^LOL!!!
Twisting words? :h
Sep-13-2019 08:54 AM
Cummins12V98 wrote:
It's funny how 14 and Shiny can't stick to what I SAID when responding or stop twisting my words. Two Peas In A Pod I say.
Sep-10-2019 07:00 PM
Sep-10-2019 08:15 AM
Sep-10-2019 08:06 AM
Sep-10-2019 07:46 AM
Sep-10-2019 07:29 AM
ShinerBock wrote:
The one good thing about the 2011+ Powerstroke is that you don't need to swap over to a CP3 to keep metal particle from getting to your injectors. Since the Ford has two fuel filters, a primary and secondary(GM doesn't), then all you would need is a $300 S&S CP4.2 bypass kit. It blocks the fuel from going straight from the pump to the injectors without passing through a fuel filter or the internal filter on the CP4 first. It will make the pump as reliable as the CP3, but it will at least mitigate the damage when it grenades.
I have no doubts that you could do the same on the new Cummins since it also has both a primary and secondary filter.
Sep-10-2019 07:22 AM
Sep-10-2019 07:12 AM
Me Again wrote:Flan wrote:
CP4 has been improved over the many years it has been out.
And is Bosch now paying Eldebrock to use patent for roller cam follows that do not turn sideways in the bore? Lack of good filtration ahead of the CP4.2 was one of Ford's issues with the pump along with warranty denials. At least GM just warrantied them until they could no long stand the failures and switched to the Demso pump.
It will be interesting to see how RAM does with the CP4.2 on the 2019+ models.
Sep-10-2019 06:48 AM
Sep-10-2019 06:20 AM
Sep-10-2019 05:35 AM
Cummins12V98 wrote:
Yep you know it all!
Wonder why you “USED TO” work at CUMMINS.
Sep-10-2019 04:57 AM
Sep-09-2019 08:24 PM
ShinerBock wrote:
Even with TH mode they shift too soon as well. Anyone who believes that what they have is the best will overlook negatives and only focus on what they want to be true. They only focus on the negatives of what they don't like or don't have.
I guess the people from PUTC and a few other sites aren't lucky because they are saying the same thing I am.
Sep-09-2019 08:07 PM
Bigfoot affair wrote:dennych1 wrote:
I’m looking at this left over and asking people’s opinion . I’ve been a GM guy so not to fimiliar with ram
One huge reason not to buy the Ram, Bosch CP4 fuel system. GM dropped that system in 2017, Ford will have a new fuel system for 2020.
