Apr-18-2016 05:15 PM
May-17-2016 04:16 AM
Perrysburg Dodgeboy wrote:
You guys running DRW had better be careful about how much you deflate your rear tires! Even unloaded the tires can rub on the inside going over bumps or hauling even minimal loads in the box. This will over heat the tires and can cause a blow out.
Don
May-16-2016 10:48 PM
May-16-2016 08:01 AM
whjco wrote:
Unfortunately, I can't offer a comparison but I can say that I'm surprised at how well our 2015 2500 Ram rides. While there's some stiffness, it's not the harsh ride of HD pickups of years past. And we've hooked our TT and it says dead level.
May-16-2016 07:55 AM
DmaxWW wrote:Cummins12V98 wrote:thecdnmole wrote:
Well I finally got to see this airrdie setup on a 3500 SRW Ram and it looks more like helper bags than actual suspension. The amount of leaf springs looks close, I didn't have time to count and measure thickness between one with and without the air. I thought it was more like a highway tractor setup with the airbags doing all the load, but does not appear so. Not sure if it's worth $1500 CDN unless your loading up to the max in payload.
The bags ARE carrying the load. The springs are there to control axle wrap and position axle.
There are two full length springs and two that go from the axle to the front spring support.
I feel the system is worth every $$$. The truck rides near level instead of AZZ high solo and rides level when towing no matter the weight up to RAWR. The ride is very nice.
The 2016 has a different spring setup with the level air, mine has 3 full length springs with a 4th one going to the front, guess they changed something on the 2016.
May-16-2016 07:53 AM
Thanks Cummins, your picture helps as it was fricken cold when I looked and didn't have time to really check it out. I can see how the leafs that are there are more for stability and control. Next thing now is a test drive!
May-15-2016 08:32 PM
May-15-2016 09:29 AM
May-15-2016 06:29 AM
CampingN.C. wrote:
So the 3500's with bags have a different leaf package than the standard 3500 without bags? Or am I reading that wrong?
May-15-2016 06:09 AM
May-15-2016 06:02 AM
May-15-2016 03:46 AM
May-14-2016 05:36 PM
Apr-21-2016 04:21 PM
FishOnOne wrote:
The dealer will not flag your truck when performing an oil change or safety recall. It's when they actually have to replace an item that they test or look at the symptoms to ensure no tuner was involved. Now there are some tuner friendly dealers but most are not.
Apr-21-2016 07:46 AM
