Ram 3500 Air Suspension - How Does It Work?
smooth1
Hello. Can you guys tell me how this system is controlled via the driver. Are there settings, adjustments, ride height info, etc.
Thinking about this system on a 2015 3500 Ram long bed SRW for a 3500lb non-slide truck camper. Just concerned about the lack of leaf springs and side to side sway. I also can't find any good info on how this system is controlled.
27 REPLIES 27
taken
Beta rider wrote:
I have a 2015 Ram 3500 drw with factory air ride and a Lance truck camper that weighs about 5200lbs when loaded. I've driven it over 3,000 miles so far and am very happy with the suspension. The ride loaded is extremely comfortable. The ride empty is better than the 2015 with just leaf springs. I think the ride empty is better than my 2008 1500 with leaf in the rear. The air ride handles the camper very well in turns and amazing at highway speeds of 65 to 70 and faster. The ride is quiet and composed and has little wind noise even with the camper on it! I will not be changing shocks or any other suspension component. It would be nice to have more control over the ride height when parked for loading, etc. I have had neck and back injuries in the past that make me very sensitive to a harsh ride. This combination is completely comfortable for me and I would buy it all over again for sure.
Thanks for the full review! I had read a couple guys on the Ram forums weren't impressed with the unloaded ride improvement. Glad to hear there are other opinions. Guess when the time comes, I'll have to try it for myself....
Regards, Rodney
TV - 2017 F350 SRW CC SB 4X4 6.7
TH - 2015 FR XLR 395AMP
Beta_rider
45Ricochet
I would assume it will dump air when off loading the weight be it a FW or TC. Isn't that the point of the system, a better empty ride?
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
taken
Cummins12V98 wrote:
No Idea how well it works with a slide in camper.
Here is a pic with over 5K sitting on the rear axle. It will look the same with 6.
Nice! So, is what I've read on the Ram forums true and the truck doesn't ride better unloaded than the same truck without factory air? Unloaded ride improvement would be just as important to me as self leveling.
Regards, Rodney
C_Schomer
Those bags look just like my FS bags and I cut off the bottom OLs and greatly improved the ride. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ib516
The Ram 2500 with air suspension has no steel springs, just airbags. The 3500 still uses steel springs but supplements with airbags.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
taken
Dupe.
Regards, Rodney
taken
2oldman wrote:
There aren't any springs according to what I see.
Here is a pic of the as delivered system.
The only way to go with a straight air system is to get the Kelderman Air system. Completely replaces the factory suspension with a 4 link air ride suspension.
Regards, Rodney
Oldme
Go to ramtrucks.com and you will see the system used.
2oldman
taken
There are still leaf springs. The air bags just supplement them. If you do Google it, you won't find the real system. You will see diagrams of what was proposed and what people were ordering, but not what is being delivered. There was a last second re-design that eliminated the track bar and added half leafs to the front side of the full leaf spring. The Ram forums have more info on this. As for control, it's all automatic. When a load is applied to the truck, the bags inflate to automatically bring the truck back to it's unloaded ride height. It can not be manually controlled.
I was big on this system and considered Ram for my next truck because of it. However, now that it's finally out in the wild, reports say the unloaded ride is no better than the standard leaf spring rear suspension.
Regards, Rodney
2oldman
Google 'ram air suspension'
