Ram 3500 DRW tire pressure
Rangerman40
So I just upgraded from a 26ft tow behind at 5500lb to a 40ft fifth wheel that comes in at 13400 empty. I usually run 80psi all around. Does that need to change with the addition of the fifth wheel? Pin weight is advertised as 2600ish dry. I haven't picked it up yet so it hasn't been on the scales yet.
17 REPLIES 17
gmc6000
Rears should be at 65 for dual wheels and front at 80 psi
2017 Ram 3500 DRW Laramie MegaCab 6.7 Aisin 4:10
2013 KZ Inferno 3710T
Rangerman40
Well I guess I'm not at 80 all around.... Fronts are 80 and rears are 70-75.
rjstractor
Since you are going up significantly in weight if anything tire pressure would go up. But since 80 psi is your max tire pressure (unless you are running 19.5s) you are already there. If anything you could consider adjusting your pressures down a bit.
2017 VW Golf Alltrack
2000 Ford F250 7.3
