Dec-12-2017 03:11 AM
Dec-13-2017 02:30 PM
ShinerBock wrote:
I have to disagree about the times not being about horsepower available. The road they use for the Ike has constant grade changes from 3% to 7%(check for yourself here road elevation map) and the inconsistency of a human (Mr Truck) foot will cause the truck to constantly loose and gain speed. There is also a very steep part at the very top and flattens out as you come to the lights at the end. Neither truck would not be at a constant 60 mph the whole way up even if you put it in cruise control.
According to how much torque each truck makes at certain rpms, I can guesstimate that the Ford has 400 hp at its disposal at 2,500 rpms, the Cummins has around 300 hp available at 2,050 rpms, and the GM has around 275 hp max at 1,600 rpms.
The next time you tow a heavy trailer, put your truck in cruise control coming up to a steep hill and you will notice that you will loose some speed as you start up the hill and will have to apply more throttle to get back up to speed. Do this in 6th, 5th, and 4th gear and tell me which gear allows you to recoup that speed quicker. I bet you it will be 4th when you are making the most horsepower.
This is why truck drivers will downshift as they are coming to a steeper grade to get their rpms up so they will have enough horsepower to maintain speed.
Dec-13-2017 12:46 PM
Dec-13-2017 12:19 PM
Dec-13-2017 08:53 AM
Groover wrote:
"I can guarantee you that the DPF's were getting hot enough to passively regen up that hill. Anytime you are at high load for periods like that will trigger a passive regen due to the DPF getting hot enough without the use of extra fuel."
Are you saying that a "passive regen" is an actual event to the engine or simply that due to running the engine so hard the filter got hot enough to self clean and no further action by the engine management system was necessary?
If they had followed this piece of advice " I am not too fond of pulling a load like that up a hill at 1,600 rpm and would rather be in the 1,800-2,200 rpm range to keep EGT's as low as possible." would that have killed the passive regen?
Dec-13-2017 08:31 AM
Dec-13-2017 08:19 AM
Dec-13-2017 07:38 AM
Dec-13-2017 07:19 AM
Dec-13-2017 06:44 AM
Dec-13-2017 06:08 AM
ib516 wrote:
I agree, they RPM "data" is useless unless we know the camera was on the gauges when the trucks were on the same spot on the hill. The grade varies.
Dec-13-2017 05:39 AM
Dec-13-2017 05:32 AM
Dec-13-2017 05:27 AM
FishOnOne wrote:Turtle n Peeps wrote:
^^^^^ this. I agree with everything that was posted above. That's why the Dmax burned less fuel. But it could have went the other way depending on load.
I disagree in the fact we don't know the actual HP/Torque numbers because the trucks were not running at WOT and full boost. The truck that can put enough power to the wheels with less throttle and boost to meet the target speed is the one that will make the best fuel economy.
Dec-13-2017 05:26 AM
ShinerBock wrote:Cummins12V98 wrote:
How about choosing a gear like 3rd or 4th and set the cruise to the speed you want to hold. Works GREAT!
I have tried the AUTO mode, the above works MUCH better! Maybe it has to do with me towing 6% or steeper grades with a combined 33-35K.
Well here lies the problem. THEY DON'T MANUALLY SHIFT THE TRUCKS IN THESE TESTS!!!!
I am not saying that regular mode does not work the best, and it does work the best if you manually shift it. However, if they want the truck to do all the work(like they do in these tests) then auto mode is the mode they need to be in.
Dec-12-2017 05:24 PM
