Oct-13-2018 06:28 AM
Apr-22-2019 06:45 AM
Apr-22-2019 03:02 AM
I agree with jaycocreek. When we had our 30 amp trailer, we would run a heavy duty extension cord through our slide to the pedestal and plug into the 20 amp plug. That way, it did not run through the camper's circuits and we never had a problem, just don't forget to unplug it before pulling in the slide
Apr-21-2019 09:47 PM
Apr-21-2019 08:57 PM
Grit dog wrote:donn0128 wrote:
Heater is a heater is a heater. All electric heaters are limited to 1500Watts. That keeps them undrr the 20A most household breakers will be. What else are you attempting to use in the same circuit? Realisticslly an electric heater must be on a circuit that nothing else is on it. Also plan on replqcing the breaker. Once they start tripping it will only get weaker.
Again, only in your world.
I have a couple electric heaters that pull significantly more than 1500W. But yes most Walmart plug in heaters are designed to work on normal household circuits.
Agree though, contrary to Dutchman, new breakers are stronger and get weaker with each flip. Same with GFCIs. They do wear out.
Apr-21-2019 04:38 PM
DutchmenSport wrote:
In my previous 3 travel trailers I could not run very much more than the standard equipment that came with the trailer. Maybe a coffee pot and a toaster, or hair blower, but that was about all.
It took some trial and error, but here's some tricks I discovered to stay within the 30 amp allocated usage all my travel trailers permitted.
1st. I always ran my water heater on gas, not electric. Although electric does not run all the time, just when it's actually heating, about the time I plugged in a space heater at 1500 watts and then the water heater turned on, it would blow the breaker. So, running your water heater on Gas, saves some electrical AMPS from that 30 limit.
2nd. When running the microwave, we always turned the air conditioners off first.
3rd. If we ran a portable electric heater, or an electric skillet, or an electric griddle, we always plugged it into the campground shore power post by running a separate orange 50 foot extension cord into the camper. Every camper we had, I was able to find a hole somewhere I could fish the orange extension cord through from the outside. The port where the camper electrical unbilical cord fed through was usually the place. I had to dismantle some paneling, but eventually I made a way to fish the orange cord and bring it inside the camper. I did this with 3 different travel trailers.
When using electric griddles or electric frying pans outside, we always plug them into the campground shore power post, never through the camper itself for this very reason.
These simple changes in the way we used the camper made all the difference in the world.
Our last camper, our Outback 298RE, I could run one 1500 watt space heater through the camper wiring as long as the water heater was on gas. I then ran a second extension cord from the campground post, put it through the umbilical port and could run a second 1500 watt space heater.
But in the Summer, if we ever used an electric skillet or the electric griddle inside, I always ran the extension cord.
This worked.
My current camper is 50 amp, and last week-end I discovered that plugging in my 1500 watt electric griddle through the outside plug on the camper popped the breaker. But I did have both air conditioners running, the water heater on electric, and the microwave running all at the same time. I went ahead and ran the extension cord and will probably continue doing so when cooking outside.
Jan-31-2019 05:23 PM
OleManOleCan wrote:
I ran a extension cord into my camper thru a pass thru
Jan-31-2019 07:13 AM
OleManOleCan wrote:
Electric heaters are pretty quite.
Jan-31-2019 07:12 AM
SoundGuy wrote:
A typical 1500 watt electric heater won't draw any more than 12.5 amps @ 120 vac so if you tripped a breaker then you've got something else running on that same circuit. Buying a different electric heater isn't going to change this, nor would you want one rated at less draw as it will also output less heat. Rather, the solution is to select whatever 1500 watt heater you prefer based on features offered and ensure it's the only device running on that circuit.
Jan-30-2019 07:08 PM
315RLTSinPA wrote:
Take a look at these heaters
https://www.eheat.com/envi-high-efficiency-whole-room-120v-plug-in-electric-panel-wall-heater-2nd-ge...
Jan-30-2019 04:53 PM
Jan-29-2019 09:03 PM
Lwiddis wrote:
My electric heater (much unused) has two settings..700 and 1500 watts. I use only the 700 setting. The basics of RV electric power aren’t difficult but IMO essential. Read and study an online tutorial.
Oct-14-2018 05:12 PM
Oct-14-2018 03:33 PM
pianotuna wrote:
Since I'm in a class C, the dash heat would not circulate and there is no "fan only" option on the furnace. That is why I replaced the return air grill with dual window fans. I've tested them to -27 c (-17 f) and there were no freeze ups of the fresh water system. The fans draw a scant 27 watts so it is easy to run them from an inverter.Huntindog wrote:
Another point. Most TTs use the furnace to keep the tanks/plumbing from freezing. In my TT, this would work down to about 6 degrees. (YMMV). That was with the furnace running. If I were to use electric heat instead, the tanks/plumbing would freeze at a higher temp.
Oct-14-2018 01:21 PM
pianotuna wrote:
Gdetrailer,
The "usual" furnace on an RV is about 5862 watts.
I do have the OEM power cord, and two auxiliary shore power cords. I have pretty good luck finding two outlets on different breakers. Three is a bit harder but still possible at some locations.
At -27 C (-17 f) my peak load goes to 7100 watts and the average is about 4000. That includes running a block heater for the car. At those temperatures I need 3 15 amp circuits--or a 50 amp with a "break out box".
