recycling-how much aluminum is in average camper?
mobilefleet
I have a wrecked 30 ft Zinger trailer, 2006 model. Local scrap yard says 41 cents/lb for scrap aluminum. Is it worth it to peel all the siding off? Have no idea how much weight the siding makes up
18 REPLIES 18
On my rebuild project from a number of years ago, I stripped all the siding off and replaced it.
After too many withdrawals from the memory banks, I don't recall the exact figure, but it seems to me I had in the neighborhood of 150 pounds of scrap. If the roof is aluminum, consider that too. A roof skin of that size will be about 125 pounds or so.
At 40 cents you can do the math and see if it is worthwhile.
Another consideration - is it aluminum stud framed?
Removing the siding is fast and easy. Start from the bottom, rip it of the staples and unhook the lowest piece out of the one above it. This will expose the staples holding the next piece to the studs. This is where it gets really easy. Quick pry with a bar or hammer from the framing to the siding and it will pop right off.
Of course, there are windows and vents to either remove or cut around.
Might be easier to cut the top piece laterally when you get there, as the drip rail is screwed on over top of the siding.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
JJBIRISH
I have dissembled a few and never come close to making it worthwhileโ€ฆ I just had to do itโ€ฆ you end up with what you started with, a lot of junk and a little scrapโ€ฆ and if every staple or screw hasnโ€™t been removed you will get almost nothing per poundโ€ฆ
I would never do it for the scrap value aloneโ€ฆ
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Caveman_Charlie
I don't know about the aluminum. But, if the frame is still in useable condition you can make a trailer out of it. Helped people do that before. They use it for a motorcycle trailer.
1993 Cobra Sunrise, 20 foot Travel Trailer.
dbbls
My guess it would be less than $20.00. What is your time worth?
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
