Jun-17-2014 02:19 PM
Jun-20-2014 04:47 PM
stahrmcgee wrote:anaro wrote:
Camping world installed my brackets backward and screwed the entire set up on my hitch, I never was able to properly seat the cams on mine because the misaligned where they put the hitch on. It was not pretty. Jbarca, rongratz and several others on here caught the error and helped me fix it. You will learn a lot about your hitch by trying to fix it yourself. Dialing it in is a painful process but worth it in the end.
Looking at my original setup, the brackets were installed correctly, just too far away from where the cams needed to be for cinching up. This forced the cam bolt shafts to be all the way extended leaving the bolt shaft to take all of the stress and torque instead of the amount they should take when about 1/3-1/2 out. This is the original problem, which I am not sure the installation tech took into account considering the size of the trailer and the associated weights. The new, further back location is better for the stresses involved, and I will admit that the trunnion bars are seated better, however the mounting bolts are now the issue...
I wouldn't have a problem repairing this myself, however, given it is covered, I would prefer to give them a chance to stand behind their product and workmanship.
Just a bit of bad luck i guess.
Jun-20-2014 12:19 PM
Jun-20-2014 11:11 AM
Jun-20-2014 10:56 AM
dodge guy wrote:
maybe I`ll take some pics of the install so all the dealers can see the proper way to install one and take notes or use them for reference!
Jun-19-2014 09:36 PM
Jun-19-2014 09:11 PM
Jun-19-2014 07:38 PM
Jun-19-2014 04:59 PM
Jun-19-2014 02:06 PM
Jun-18-2014 05:10 AM
Jun-18-2014 04:36 AM
Jun-18-2014 04:24 AM
Jun-17-2014 08:45 PM
Jun-17-2014 08:36 PM
