Removing one side tires
traildog
I need to take the tires off of my TT (preferably 2 at a time) to take them to the tire store for replacement.
The store won’t remove them (an quite frankly, I’m ok with that). So, how can I lift one side at a time safely, to remove the tires?
2021 Coachmen Freedom Express with a wide gap between the tires.
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
40 REPLIES 40
valhalla360
Nomad III
Nomad III
traildog wrote:
ferndaleflyer wrote:
He said they won’t do that. I would get a couple of blocks and put them in front of the front wheels, pull forward till the back wheels were off the ground. Remove, get new tires, replace and back off. Now do the same for the front wheels. Loosen the nuts while it is still on the ground.
They don’t have the space for my RV.
Go to a different tire store. Even if it's a few bucks more, well worth if for saving the hassle of running back and forth.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Put the spare on one and leave the other on the jack. Or even better.... find a different tire store.
Lantley
They won't sell you new tires and install them???? I would look for another Tire store.
Mythoughts too. I understand there are shops that simply don't have the room.
However there are alternative shops that do have ample room.
Seek those larger places out and take your rig there.
JGCorm
I see a lot of post on this board suggesting the one wheel on blocks to remove other wheel.
I tried that and with all the weight of one side on one tire I bent the axle.
Gonzo42
I do business with America's Tire. All my vehicles. My class C got a full set of tires not long ago, and they did all the removal, mounting, balancing and install in one trip. I also paid for the insurance, and collected a new tire on two vehicles due to road debris damage.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
traildog
IAMICHABOD
If you are going to do all 4 why not just do one axle at a time. Just run one axle up on a ramp,then the other.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Lwiddis
I use a home built wood ramp. I suggest you remove one tire and replace with the spare. Remove the other tire again using the ramp and proceed to the tire store. Reinstall the two new tires. Repeat on the other side.
MarkTwain
ferndaleflyer
MarkTwain
Avoid the hassle:) just take the trailer into the tire shop and buy tires and let them remove and install tires.
