โJan-16-2022 10:59 AM
โJan-16-2022 08:50 PM
MarkTwain wrote:TxGearhead wrote:
I've got a 2018 RAM diesel, dually, crew cab, long bed. It is also blessed with a 32 gallon fuel tank.
Has anyone replaced that tank with a larger one? I'm looking at Titan and S&B brands. The S&B is 60 gallons so I'm leaning that direction.
Only issue is the Torklift mounted on the front drivers side. It looks like it could be a tight fit up against the tank.
Has anyone done this swap with Torklifts?
Thanks in advance...
I suggest you contact "Transfer Flow" in Chico Calif. and talk to them about replacement diesel fuel tanks. Great company and quality work. They have many choices of tanks. I have bought 3 different tanks from Transfer Fuel on different tanks and they have worked great. They can install a new tank in 1 day.
โJan-16-2022 08:44 PM
ford truck guy wrote:
I HAD a Titan 51 gallon in my last truck and loved it... It gave me the option to fill when I wanted to fill... Its not always about the bladder....The Titan OEM replacement fits in the same location as the factory, OEM... BUT I cannot speak for the Torklift.......
โJan-16-2022 08:43 PM
Bedlam wrote:jdc1 wrote:
I just figure I need to pee or stretch my legs every few hundred miles. Why not do that while filling up?
Some areas or states have much higher fuel costs. If you can drive through those areas rather than fuel up there, your flexibility stills allows you to make stops for other reasons.
My only question is whether you have sufficient payload to carry that additional fuel.
โJan-16-2022 08:30 PM
Supercharged111 wrote:
Because it's the strongest bladder that determines the stops, not the weakest.
โJan-16-2022 08:27 PM
n0arp wrote:
I had the Titan 55 gallon midship replacement on my 2019 Ram 3500 DRW, and used the Torklift frame ties with no issues. The 2018 is supposed to be slightly different, but I'm not sure exactly how.
โJan-16-2022 05:56 PM
โJan-16-2022 05:24 PM
โJan-16-2022 03:11 PM
โJan-16-2022 01:42 PM
โJan-16-2022 01:32 PM
โJan-16-2022 12:59 PM
โJan-16-2022 12:45 PM
