Rieco Titan Tripod Jacks - Twisting/Leaning, Need Help
flysar
I have had 1000lb Rieco Titan tripod jacks on 2 different lightweight pop-up campers. It doesn't matter if I use 3 or 4 the camper always leans or twists when lifting off the storage platform or truck. This is on level ground.
They are still manufactured and used by thousands of folks so there must be a trick to it that I haven't figured out.
Any tips other than swap them out for corner jacks?
1 REPLY 1
whizbang
I have the same jacks on a Jayco pop-up. Since my driveway slopes pretty good, the camper always leans toward the downhill side (the front).
I had one occasion to raise the camper on a level spot and I was astounding by how much the camper swayed and twisted. Scary creepy.
I suspect what you are seeing is normal. Good luck.
Whizbang
2002 Winnebago Minnie
http://www.raincityhome.com/RAWH/index.htm
