Roll Up Bed Covers
Bob__B
Who uses a bed cover when the camper isn't on the truck? If I'm going to be at one place for a while, I take the camper off the truck. Easier to launch the boat and generally run around.
I'm looking for a bed cover that is easy to remove or roll up out of the way.... and doesn't increase the bed rail height....or increases it minimally.
I already have to use some rigid foam in the bed to raise the camper enough to clear the bed rails.
2007 Lance 1181, 2013 Chevy 3500 DRW
10 REPLIES 10
OH48Lt
Will the bed cover mounting hardware that is attached to the inside of the top rail pose a clearance problem whenever you want to slide in the camper?
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
Bob__B
Well, I'm pretty surprised that it is all Truxedo with the large variety of covers out there .... Think I better check them out.
finsruskw
X2 on the Truxedo!!
Mine comes off during camper season and is stored in the original boxes alonside the t/gate, on the dolly the camper, tie-downs, Super truss ad chains are stored on in the non-camping season.
punomatic
newman fulltimer wrote:
look at truxedo covers
X2 Love my Truxedo.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
newman_fulltime
get a net gat put on when needed
azdryheat
I use a Truxedo
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Bob__B
Well .... I just thought of another problem. When I'm camping and the camper off the truck....I'm also not going to have the tailgate with me. No way am I going to try to carry that around with me.
Don't know why I didn't think of that before.
That Truxedo Lo Pro does look like it comes on and off pretty easy. I may just have to resign myself to doing that since the width reduction may be a problem also. I don't have that much clearance now when loading the camper.
I could see the mount and/or the camper being damaged pretty easily.
northshore
I have one, but I believe it takes up too much room at the cab end of the bed to have it and the camper on the truck. Mine is aluminum and rolls into box type container right behind the cab. Its a hard surface and it locks pretty securely keeping things safe. I had a soft roll up tonneau cover on a different truck and that might be a solution, it rolled up pretty tight but still took up room right behind the cab.
On my trucks neither one would have bothered the bed rail clearance for the camper.
My roll up aluminum cover is Pace Edwards I think, and the soft one i can't remember what brand that was.
maxum1989
I have the truxedo low profile but my Northern lite camper fits very close to the side rails of my truck so I have to remove it to load the camper. It just depends on the size of the your camper in relation to your truck box. The rolled up part of the cover I believe would be fine in the front with your camper loaded. It would just shift forward a little. Its the side rails you need to pay attention to. The project upwards very little but they do shrink the available width for the camper a few inches.
2008 Chevy 2500hd Duramax/Allison
2006 Wildcat 27 bhwb
2009 Lance 830 *Sold*
2011 Northern Lite 8.5 *Sold*
newman_fulltime
