โMay-22-2017 02:53 AM
โMay-22-2017 05:11 PM
โMay-22-2017 05:04 PM
โMay-22-2017 12:08 PM
swimmer_spe wrote:
OP here.
I thought it was illegal to use any propane appliance while the trailer is in tow.
I was planning on just 12v, no propane on.
โMay-22-2017 10:22 AM
โMay-22-2017 10:18 AM
โMay-22-2017 09:48 AM
Hannibal wrote:
I start mine plugged into shore power on propane a couple of days before we load up. Then battery/propane on the road and shore power/propane at the campground. I've never seen one that runs on 12vdc alone.
โMay-22-2017 09:42 AM
โMay-22-2017 09:38 AM
โMay-22-2017 08:19 AM
SpeakEasy wrote:ScottG wrote:
Your fridge will be ok, just let it run on the auto setting as you go down the road. The truck will provide the 12V and propane will keep it cool.
It's a great system that requires no attention. Just let it do its thing.
Your answer assumes three things:
(1) the charge line from the truck's 12v is live
(2) the propane tank is open
(3) the OP WANTS to cool with propane
But the OP was asking about cooling with 12v.
-Speak
โMay-22-2017 07:45 AM
โMay-22-2017 07:39 AM
โMay-22-2017 06:10 AM
Tvov wrote:dave17352 wrote:
If you refrigerator runs on 12 volt and it is a typical propane, 12 volt, and 120 ac design it will us a ton of power on 12 volt and kill you TC battery in a few hours. I think they draw close to 20 amps 12 volt. The 12 volt really should only be used when your truck is running and charging and you should have a heavy gauge wire from your truck to your truck camper. Lance requires 8 gauge.
I'm not sure if I am following, and/or truck camper frigs are different. The Dometic in my TT runs on propane / battery, or AC if hooked up to shore power.
When running on propane, the TT's battery lasts for days, we can stretch it to a week if careful with lights and other power usage. Propane frig needs the battery to run, but seems to draw very little power from it.
โMay-22-2017 05:44 AM
swimmer_spe wrote:
I want to load up my fridge at home. It is a 3 way fridge. Will the battery be charging from my truck? How long typically will the battery last with the fridge on and not charging? Once I get to my site, I will be hooking up to shore power.
โMay-22-2017 05:36 AM
โMay-22-2017 05:26 AM
