Jul-15-2013 08:00 AM
Jul-15-2013 08:21 PM
Jul-15-2013 06:32 PM
Jul-15-2013 12:17 PM
JJBIRISH wrote:
if rubbing is a concern a piece of rubber roof membrane glued to the platform should solve that…
Jul-15-2013 12:00 PM
Jul-15-2013 10:41 AM
dap wrote:
I have a 2008 Starcraft 24 RQB TT. My problem is in draining the gray tank, at first it will flow fast and then slows to a trickle which will go on until I loose patience or the line at the dump station gets busy. I have checked for obstructions which is all clear. The problem appears to be the thin plastic bottom of the gray tank has sagged and now traps about 2-3 gallons in that section.
Jul-15-2013 08:53 AM
Jul-15-2013 08:49 AM
Jul-15-2013 08:10 AM
